Author Subject: Why the offset turbo charger??
talbotsteve
I've noticed almost all turbo conversions go down the route of the T16 type manifold with the turbo sat over the gearbox more or less, why is this? Is it just that there is no room behind the engine?
The TD's seem to have no problem with room, surely a hybrid gti6 flange and sliced td manifold would fit down there? then you could use a td down pipe.
Wouldn't this be a lot cheaper than the big expensive manifold?
Just askingThumbs up
Steve.
MMMM you won't like this but I just love Citroens!!!!!!!
Posted 22nd Nov 2012 at 23:07
JWP EFi
Turbo Legend!
there just isnt the space behind the engine, TD uses 'log' type manifold and very small turbos
TD downpipe would be way to restrictive
Posted 22nd Nov 2012 at 23:13
no room indeed.
Posted 22nd Nov 2012 at 23:19
dcc
MAKE ROOM
205 GTI
Xsara HDI
Posted 22nd Nov 2012 at 23:20
you ever changed a 306 hdi turbo? LOL
Posted 22nd Nov 2012 at 23:21
JWP EFi
Turbo Legend!
Yes
pete_rallye
Are all the XD engines single cam? I know my old HDi DTurbo was and the single cam head leaves a fair bit of room behind it compared to a twin cam, plus the manifold is a bag of s**t, if you want anything half decent you'd need a lot more space.
Lap of the 'ring
Posted 22nd Nov 2012 at 23:31
not sure, my hdi is single cam but it was still tight behind the head. it'd have been miles easier to do otherwise. then again it wasn't hugely hard but space is so tight you end up removing quite a bit. inlet out and engine off the top mount to push it forward enough for removing all the manifold and exhaust studs.
some people do it from underneath, atleast once it's rocked forward you can see what's what. bad job though. 4hrs approx but some head scratching took the time too
Posted 22nd Nov 2012 at 23:46
the turbo is only a little Garrett m9 too
Posted 22nd Nov 2012 at 23:47
JWP EFi
Turbo Legend!
i suppose if you were to turbo a GTi6'd 205 then it would be a little easier as theres a little bit more
space between engine and bulkhead, but not much more!
even the 406 8v turbo conversion has clearance issues and thats still with a small turbo, iirc you
have to extend the bottom mount by 10mm, which isnt an ideal way to do it
Posted 22nd Nov 2012 at 23:52
JWP EFi
Turbo Legend!
...and on the 306 you have to cut (i did) the 'rib'that runs along the bulkhead for the turbo to clear
even after doing that you could only just get your fingers between them
Posted 22nd Nov 2012 at 23:58
talbotsteve
There are flange conversions to fit td04's to the td manifolds using the std down pipe ect.
So space is tight but not impossible.
Mmmmmmm.
I was looking at the other thread re the s16 turbo and he runs a stock bottom end/headgasket up to 250bhp on low boost.
That would do....wouldn't it, if it was a 1.8 bottom end?
Posted 23rd Nov 2012 at 00:20
JWP EFi
Turbo Legend!
no one said it was impossible, in fact theres a video on youtube somewhere of a Brazilian (i think)
chap who mounted a T4 behind the engine in a Xsara VTS
Posted 23rd Nov 2012 at 22:02
JWP EFi
Turbo Legend!
'xsara vts 98 turbo'
worth a look, and he used standard ecu
Posted 23rd Nov 2012 at 22:04
JWP EFi
Turbo Legend!
Posted 23rd Nov 2012 at 22:08
