displaying posts 1 to 25 of 30
Author Subject: ICV Issue?
darkstar753
My car is having days where it is refusing to idle nicely, both whilst stationary and whilst coasting.
On a bad day it does this whilst stationary:Video(not my video but pretty much exactly what happened on the weekend)
Also the car is lovely and jerky when transitioning to idle, right to assume this is associated?
I gave the ICV a good clean, it was covered in lovely black greasy-ness. Seemed to have fixed it on Sunday but alas monday moring comes and its back again! Took ICV off quickly at work, still clean, yet still playing up!
I have ordered a new ICV but is there anything else that may be playing a part in this?
Darkstar
Posted 6th Nov 2012 at 08:26
rich306
The other guys will tell you more but would a MAP sensor cause this to spike? sooooo many sensors around the throttle body housing!
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 6th Nov 2012 at 08:43
MAP or lambda could cause this issue as well. Yes
Posted 6th Nov 2012 at 10:17
darkstar753
Is the MAP sensor something that could be cleaned first before forking out for a new 1?
Darkstar
Posted 6th Nov 2012 at 10:23
doesnt do one bit of difference in my experience.
Posted 6th Nov 2012 at 10:26
darkstar753
Hmmmmm, well new ICV should turn up today, so fingers crossed.
Also as is normal for my french piece of c**p, the problem appears to have disappeared this morning :@
Darkstar
Posted 6th Nov 2012 at 10:29
Glad to see you've got plenty of love for the car... LOL
Posted 6th Nov 2012 at 10:35
darkstar753
Obviously LOL its great when its working! also a good job my works mileage expenses are rather generous
Darkstar
Posted 6th Nov 2012 at 10:52
Matt_rallye
Anyone shed some light how the lamda can cause this?
Posted 6th Nov 2012 at 11:37
because the lambda isnt giving a steady signal the ecu is getting confused all the time.
Posted 6th Nov 2012 at 11:44
darkstar753
Would a lambda fault like that show up if I were to get my hands on some form of diag tool ?
Darkstar
Posted 6th Nov 2012 at 11:58
Matt_rallye
Stick it on Peugeot planet Wink
What does the lamda read exactly to get it to confuse the ecu?
Posted 6th Nov 2012 at 12:04
Anything! it should osscillate between 0.1-1.0v IIRC, if it goes too low or high it can confuse the ecu even further.
Posted 6th Nov 2012 at 12:38
Matt_rallye
Ahhh right, having similar issues to the op. going to give mine a go over with Peugeot planet and check my lamda reading at the weekend Smile
Posted 6th Nov 2012 at 14:05
darkstar753
You replaced the ICV already then? fingers crossed it fixes mine, getting a tad annoying for my only car!
Darkstar
Posted 6th Nov 2012 at 14:13
Lambda faults sometimes show up on a diag, sometimes not. However, as said if you get it plugged into Planet you can view it live and see what readings you're getting. Smile
Posted 6th Nov 2012 at 14:23
Matt_rallye
I've replaced my icv twice, Fooby (the guys who's video you used) just cleaned his and it sorted it.
I need a genuine brand new replacement icv and a couple other things. I'd also check the icv is seated properly
Posted 6th Nov 2012 at 14:25
darkstar753
Yea I cleaned mine and it seemed to sort it, only for it to return. Ordered a pattern one as I didnt really want to pay £150 for a genuine one!
How can it not seat properly? not exactly any leeway when screwing/bolting it into place.
Darkstar
Posted 6th Nov 2012 at 14:32
Sometimes a clean works, sometimes not. However, in most cases where a clean does work it is generally only a temporary thing and the unit soon needs replacing after to completely cure the problem. Yes
Posted 6th Nov 2012 at 14:37
Matt_rallye
The o ring maybe loose and get snagged, on mine I had an oversized o ring which caught the side and let air past the seal
Posted 6th Nov 2012 at 14:41
darkstar753
This is what I had read a few places (and am hoping it is).
Matt, I understand now, was thinking more of the ICV than the housing that bolts on/its screwed onto. Was looking at the o-ring as I was putting it back together as the light was dieing on sunday thinking I wonder if that could be an issue.
But hey hopefully find out later Smile
Darkstar
Posted 6th Nov 2012 at 14:49
swiftyboi006
Any news?
Black p3 Love
Posted 6th Nov 2012 at 17:03
honestly3k
LOL how much do you get? I get 35p a mile which is ehem....rather s**te Thumbs up
Posted 6th Nov 2012 at 17:06
darkstar753
swiftyboi006 wrote:
Any news?
No Angry bloody part hasn't turned up, tomorrow maybe. On the plus side, car was perfect on the way home
Unsure
I get 45p per mile, but its 95% motorway miles and i get between 30/35mpg so it doesn't work out too bad.
Darkstar
Posted 6th Nov 2012 at 17:53
swiftyboi006
^^ well its probably not that good either considering tyres, brakes rubber bushes and all other things that go wrong such as idle control valves Whistle
Black p3 Love
Posted 6th Nov 2012 at 18:05
