displaying posts 1 to 25 of 35
Author Subject: 205 radiator in a 306
soton_s16
Can I use a 205 radiator in my 306 S16? Will it straight in without needing the hoses modified/ changed? Also, will it be big enough?
I have throttle bodies, and I can't fit an airbox on them as the rad is in the way. But having received quotes for a shorter rad, I am seeing if there is a cheaper option...
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 3rd Nov 2012 at 21:19
JWP EFi
Turbo Legend!
you'll need to fit a remote header/expansion tank, also you may as well use the 1.8 td item, its much
thicker
Posted 3rd Nov 2012 at 21:23
JWP EFi
Turbo Legend!
...and the hoses are a push fit with jubilees rather than the stupid bayonet fittings
Posted 3rd Nov 2012 at 21:24
BOOM
http://www.306gti6.com/forum/showthread.php?id=74819&page=8
Posted 3rd Nov 2012 at 21:44
soton_s16
Thanks for the link, but I can't find where it states what radiator he is using...
Posted 3rd Nov 2012 at 22:08
its a 205 gti rad.
Posted 3rd Nov 2012 at 22:13
soton_s16
What else will I need
Radiator
http://www.ebay.co.uk/itm/PEUGEOT-205-309-1-6-1-9-GTI-8v-1-8-TD-TWIN-CORE-HIGH-FLOW-ALLOY-RADIATOR-/230874156618?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3A205&hash=item35c12c0e4a
Header tank
http://www.ebay.co.uk/itm/ALLOY-HEADER-TANK-BUDGET-KIT-CAR-RACE-RALLY-/400217271196?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2eceeb9c
Fan
http://www.ebay.co.uk/itm/SPAL-FAN-VA07-BP12-C-58A-24-VOLT-/320999065510?pt=UK_BOI_Restaurant_RL&hash=item4abd0907a6
I want to get some silicone hoses. I presume I will need a custom set?
Posted 4th Nov 2012 at 11:01
I wouldn't bother with an alloy header tank, just use a 205 one Big grin
you could use most of a BBM or Pugracing 205 gti6 hose kit.
I would make up a steel frame to mount the fan on and secure the rad, don't forget rubber buffers for the rad, that rad looks quite a bargain if its decent!
Posted 4th Nov 2012 at 11:19
rich306
Learn something new everyday Wink
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 4th Nov 2012 at 18:53
devere
Bit of a bump here. Would the 205/GTi6 hose kit be everything needed to get the 205 rad to work with the 6 engine in a 306? By that i mean just hose wise, i know the header tank is needed.
Posted 12th Nov 2012 at 20:34
miles
Everything is a different length and shape pipe wise
www.pugracing.com
Posted 14th Nov 2012 at 22:14
devere
So on that's basis Miles, is there an off the shelf solution...?
Posted 14th Nov 2012 at 23:52
miles
No, But there could be either 2 ways, A new 306 type rad with a plain lower fitting with a new silicone hose or have a fitting fitted onto a rad, either way not that cheap
www.pugracing.com
Posted 18th Nov 2012 at 01:54
blandy
Bit of a bump but did anyone fit the 205 rad in the end? Just looking into this for mine
Posted 7th Apr 2013 at 08:22
In welshpugs link above they did.Thumbs up
Posted 7th Apr 2013 at 11:02
blandy
Yeah but theres no real info about it or not that I could see when I read through it yesterday just wondering what hoses to use etc
Posted 7th Apr 2013 at 12:48
It's going to be a suck it and see jobThumbs up
Get a rad,make brackets/get it to fit,make up hoses to fitWink
In my 309 I got rid of standard cowling,this allowed the rad to be mounted further forward and lower.
Pic below of the bracket my m8 made for me:
Gave me loads of room between rad and inletCool you can see I had a bracket made up for the top mounting on rad too,and had it welded to rad:
Would have been perfect for airflow to ITB's as you can see below:
Presume you would be cutting up your grill to allow direct airfeed?Dunno
Posted 7th Apr 2013 at 16:33
blandy
Thanks those pics help alot I've pretty much decided on a 205 rad and like you say going to get a rad and make brackets etc and then pipe from there once I've got everything sorted. How does the header tank fit pipework wise
And yes cutting and making new panel to drop lower down to get everything out of the way of the throttle bodies
Posted 7th Apr 2013 at 16:39
On the 309 the header tank had 3 connections,2 to the top of tank,and one on the bottom,top ones were: from the small bleed pipe on the rad,and another bleed point from the thermostat housing.
The bottom connection feeds into the pipe that goes from thermostat housing to the rear of water pump.
You can see the header tank top right of pic above on the bulkhead,radiator bleed pipe is visible on the top left of radThumbs up
Posted 7th Apr 2013 at 19:33
allye
On a road car i have to say I would not suggest fitting a 205 Radiator. In both my GTI6 engined 205's I used 205 radiators, nissens alloy items. It would run hot in traffic in no time and I was never really happy with it. In a heavier car I can only imagine it would be worse. If you're set on a 205 radiator at least use a diesel turbo item.
205 Van SC'd GTI6 - because why not
309 Goodwood V6 - sold
205 Rallye GTI6 - Bent
Posted 7th Apr 2013 at 19:46
Using which senders for your temp gauge?Wink
Posted 7th Apr 2013 at 19:55
beez_neez_gt
WTF, 205 rad into a 306 title not 306 engine into a 205 car using 205 rad thread??
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 7th Apr 2013 at 22:37
blandy
Nice to see something different every now and then.
Posted 8th Apr 2013 at 11:09
blandy
Also been looking into custom radiators would It be better with a remote header tank or one built into the rad like standard bearing in mind it would be a smaller but thicker rad?
Posted 8th Apr 2013 at 11:25
Check the bbm facebook page, they can do custom rads and stew has one on his t16 306 track car project.
Posted 8th Apr 2013 at 11:34
