Author Subject: 206 GTI beam question
JWP EFi
Turbo Legend!
ive just finished rebuilding a beam for a customer and was wondering if anyone knows why the o/s pin is 47mm diameter
as opposed to the n/s being 50mm, seems strange why Peugeot would do this
Posted 3rd Nov 2012 at 20:04
JWP EFi
Turbo Legend!
also n/s arb is welded to roll bar, but it wont pull out from n/s, i wound the o/s plate off using a an m10
bolt, weird setup
Posted 3rd Nov 2012 at 20:56
JWP EFi
Turbo Legend!
meant to say arb end plate
Posted 3rd Nov 2012 at 20:57
how did you rebuild it without removing the ARB?
not weird to be welded, all 206's are like that.
dont get what you mean about the pins, they should both be the same diameter, as both sides use the same bearings, most likely to be severe wear if there is a difference and you have just f**ked up by putting it all back together.
Posted 3rd Nov 2012 at 21:01
JWP EFi
Turbo Legend!
i managed to get the n/s plate off (not an easy task btw), its seems a bit strange why they did it this
way, surely if arb has to come out from n/s then you'd have the removable plate there?
Posted 3rd Nov 2012 at 21:03
JWP EFi
Turbo Legend!
no ive not f**ked it up, the bearings are different for each side, luckily the pins weren't worn, got away with fitting new bearings
trust me though, one side is a larger diameter
Posted 3rd Nov 2012 at 21:06
no, you just pull the whole arb out with it after removing the o/s plate, same as you do on a 205 309 and 306.
only the n/s has the alignment mark so they go back on in the same place so you don't have any misalignment when re-assembling btw.
if the pins really are a different size left to right how do you explain identical part numbers left to right ??
Posted 3rd Nov 2012 at 21:08
JWP EFi
Turbo Legend!
i asked the exact same question when i ordered the parts from peugeot as there was a confusion
the o/s bearings share the same part number as the 1.6 cc model, yes it all seems very odd but
the pins have no wear in them so their not heavily worn
..i feel like stripping beam apart again to show you
Posted 3rd Nov 2012 at 21:16
jonnie205
The disk brake sport beams with thicker main tube do have different bearing sizes left to right
Posted 5th Nov 2012 at 11:15
Thats interesting, wonder why?
Posted 5th Nov 2012 at 12:26
jonnie205
seems strange, i can understand if they were both larger but to make one larger and not the other Crazy
Posted 5th Nov 2012 at 12:28
JWP EFi
Turbo Legend!
Thumbs up
Posted 6th Nov 2012 at 06:41
what?
Posted 6th Nov 2012 at 10:23
JWP EFi
Turbo Legend!
your above comment that suggests i had f**ked it up, clearly i didnt
Posted 6th Nov 2012 at 18:11
so?
Posted 6th Nov 2012 at 18:14
miles
Ban
www.pugracing.com
Posted 11th Nov 2012 at 22:50
^ LOL Unsure
Posted 12th Nov 2012 at 11:57
