| Author | Subject: Thread ruined on top mount bolts |
pugbug
Regular Location: Leicester Registered: 04 Dec 2008 Posts: 154 Status: Offline |
The 306 I purchased last year had a upper strut brace fitted, it appears as though the previous owner has damaged the treads either side (3 either side on top of the top mounts) I purchased some bolts from swampy and they don't lock in place. it doesn't seem likely I'll be able to tap a thread of the same size in there, any ideas? |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Change the mounts??Not that bad a job and Yuo can put new bearings in at the same time |
JWP EFi
pugbug wrote: The 306 I purchased last year had a upper strut brace fitted, it appears as though the previous owner has damaged the treads either side (3 either side on top of the top mounts) I purchased some bolts from swampy and they don't lock in place. it doesn't seem likely I'll be able to tap a thread of the same size in there, any ideas? i'd go with what swampy said, but you could drill and tap them out to M10, but getting the 3 bolts to line up with holes in chassis could be fun |
pugbug
Cheers for the replies guys. I'll have a look into to doing that. I'm not sure how everything bolts together, but is it safe to continue driving like this? It's not like anything is going to fall out? |
JWP EFi
personally i wouldnt drive it, get it sorted!its fairly straight forward, you'll need to remove the strut, compress spring the take mount off i really would just replace it rather than trying to drill/tap, plus their likely to be worn so replacing mounts/bearings will help to tighten things up a bit |
it'll be fine on 2 bolts, the zx only had two.you could just send a 10mm tap through it after drilling to 8.5mm. Or use a longer M8 bolt and a nut underneath. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
smithers
Seasoned Pro Location: Glasgow Registered: 22 Nov 2004 Posts: 1,016 Status: Offline |
Did someone not do a trackday with no bolts in?________________________________________ 1997 Black GTi6smithers205 at hotmail.com |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
welshpug! wrote: it'll be fine on 2 bolts, the zx only had two. you could just send a 10mm tap through it after drilling to 8.5mm. Or use a longer M8 bolt and a nut underneath. It's a right b**ch to get the nut on underneath though!! ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
darzmat
Senior User Location: nairn Registered: 14 Jan 2011 Posts: 879 Status: Offline |
rich306 wrote: welshpug! wrote: it'll be fine on 2 bolts, the zx only had two. you could just send a 10mm tap through it after drilling to 8.5mm. Or use a longer M8 bolt and a nut underneath. It's a right b**ch to get the nut on underneath though!! a couple o mine are nuts and bolts as i knackered my threads by over tightening. never ad a problem taking them on or off ________________________________________ 1997 blaze GTI-6 bought january '11 £800 Spend to date on parts £827.88 |
