Author Subject: Battery light!
bengti6
Jumped in my gti6 this morning only to find battery light on and stays on, was fine last night. Started up fine and has done all day, relised as well elec front windows not working either seems strange to happen at same time. Battery is nearly new, and all wires to alternator seem ok. Could it be alternator? Any ideas anyone. Thanks in advance
205 gti6 1989
Posted 3rd Nov 2012 at 13:43
fatlapit
Alternator or your belt is missing
Posted 3rd Nov 2012 at 13:47
bengti6
Belt is there and good, seems strange how it could go over night and a coincidence that windows have stopped aswell
205 gti6 1989
Posted 3rd Nov 2012 at 13:53
tvrfan007
Rear wiper working by chance? Take the relay out, replace the fuse which you will find has blown, and ta-da.
Had the same years ago on my HDi, no elec windows, rear wiper dead, alt light on.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 3rd Nov 2012 at 14:47
tvrfan007
I should add I mean the blue relay attached to the rear wiper motor in the bootlid. This will be all green inside I suspect. Fuse 28 will be blown i suspect if you have a Phase 3.
I'm Si btw Tee hee
Posted 3rd Nov 2012 at 14:49
Good call. Thumbs up
For some reason there is a fault with the design which allows moisture to enter the rear hatch and penetrate the rear wiper relay causing it to corrode and subsequently fail.
Posted 3rd Nov 2012 at 15:32
tvrfan007
I get it all the time... Laugh Search search search would've helped actually as your thread title would've lead you to these two! Smile
http://www.306gti6.com/forum/showthread.php?id=105942
http://www.306gti6.com/forum/showthread.php?id=128328
Thinking back I was in Cov at the time, so it'll be 2006/7 when mine did it!
I'm Si btw Tee hee
Posted 3rd Nov 2012 at 16:10
I'm not surprised you suffer with this problem Simon if your car sits on the drive all the time whilst you're driving Kia's in SA! LOL
It doesn't get moved and is completely open to collect every rainfall. Sad
Posted 3rd Nov 2012 at 18:57
bengti6
This indeed was the problem thanks guys, how I would ever have found that I don't know. Removed relay and then replaced fuse only for it to blow instantly, unplugged rear wiper completely then replaced fuse and all ok. Would that mean that the whole wiper unit at fault? Or just the relay?
205 gti6 1989
Posted 4th Nov 2012 at 16:21
tvrfan007
Both are probably dead. I couldn't salvage either and replaced the whole lot. Buy a whole phase 3 unit with relay. I nearly said that the whole thing might need replacing, and you might need to unplug it all.
I'm Si btw Tee hee
Posted 4th Nov 2012 at 18:06
tvrfan007
And Stan, it's only died twice lol.
I'm Si btw Tee hee
Posted 4th Nov 2012 at 18:07
