Author Subject: dodgy plugs
boost
as a few of u know i recently posted about my tappets, n after a few replys, a few things that kept popping up on a regular basis were the injectors and plugs. well after some inspection n a bit play i give in n bought a new set of plus n changed them n as i was takin them out i noticed they wernt as tight as they should be. inparticular pot 2, wasnt even tight and was full of oil so i changed them n now the noisey knocking noise from the top of my engine has now changed to a very quiet ticking noise so would that be the injectors ??
but off topic a bit i would just like to say thanks for the advice i now have rid of the annoying knock Big grin Thumbs up
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 27th Oct 2012 at 13:11
It sounds like you were lucky and the tapping noise was indeed a loose plug not bent valves. Smile
The light ticking you can hear will be the injectors yes, they are quite noisy on these cars.
Posted 27th Oct 2012 at 17:36
boost
good good am glad its turned out to be a simple fix all a need now is the manual au tensioner then the car will be sound Smile
Posted 27th Oct 2012 at 17:48
I am glad for you that it turned out to be a simple fix. Yes
Those manual tensioners can be a bit of a pain to fit, you will find a 13mm ratchet spanner will make your life much easier when it comes to doing that job. Wink
Posted 27th Oct 2012 at 18:57
boost
i managed ok with a normal spanner lol what i found to be a pain is the gap between the engine and the car i hate having to take off mounts Sad
Posted 27th Oct 2012 at 19:30
JWP EFi
Turbo Legend!
a little advice, before fitting the rallye aux belt idler, run an M8 tap through the 2 bolt holes, i fiited
these bits to a members car last weekend, i tried to gently run a greased bolt through and ended up
shearing it, i had to remove the pas pump and alternator just to get the cast iron bracket off so
i could drill out the broken bolt, also had to take the manifold off as one of the 16mm nuts were
tight as feck, a simple job turned out to be a 3 hour long affair!
13mm ratchet spanner with flexi head is indeed your best friend here lol
Posted 27th Oct 2012 at 20:10
boost
lol a can imagine mate there seems to be no room at all in thysese engine bays
Posted 27th Oct 2012 at 21:22
I'm not sure what car Boost has, but judging by his earlier replies he already has the manual tensioner and it's running noisily, therefore dirt/corrosion in the bolt holes shouldn't be an issue when it comes to fitting a new one. Smile
Posted 28th Oct 2012 at 12:22
boost
ive had 3 mate all 2nd hand scrap basicilly in need of a decent one cause the noise is uneartly n i have an 1.6 xs qith a 6 conversion Big grin so cheap to insure
Posted 28th Oct 2012 at 12:26
I'm guessing then you already had the non-AC setup on the aux belt when the conversion was done?
Posted 28th Oct 2012 at 17:47
fatlapit
glat its not a bent valve
Posted 28th Oct 2012 at 17:50
The problem is with these is that if you bend a valve it will always be a pair. Wink
Posted 28th Oct 2012 at 17:53
boost
yea was non aircon setup tbh i think they pull alot better without the aircon n im over the moon its not a bent valve theres loads of life left in it yet all i need is that bloody tensioner Sad
Posted 28th Oct 2012 at 19:47
You can get them brand new for under £30,local motor factors or E-BayThumbs up
Waste of time and money as you've found with second hand onesYes
Most people over tension the belt,and this prematurely wears the bearing out in the tensionerWink
Posted 28th Oct 2012 at 21:42
boost
cheapest i found mate was 54 quid might just have to bite the bullet n buy new lol
Posted 28th Oct 2012 at 22:31
Buying new is the only real way of solving this once and for all as Coskev says. Yes
It's open the wallet time...
Posted 29th Oct 2012 at 09:45
boost
it always seems to be open my wallet time where me 6 is concerned and its always fuel Confused Big grin
Posted 29th Oct 2012 at 10:18
