Author Subject: 5mm hubcentric spacers
Need some 5mm hubcentric spacers for the front of my 6 to clear the brembo's. Believe it or not the 17's I'm about to put on don't clear even though their the correct offset.
Posted 24th Oct 2012 at 13:41
Is there such a thing? Why not just use normal spacers that'll cost you about a pound?
Posted 24th Oct 2012 at 16:02
Have normal cheapy ones waiting to go on but they suck hoop and are impossible to get central as the centre bore is massive. Wanna be able to hack it through the twisties with some nice tight fitting ones. Demon tweaks do them and a few other sites or egay all for £40 ish. Was just seeing if anyone has some kicking about Wink.
Posted 24th Oct 2012 at 16:06
Fair enough, can't argue with that logic. Must say I found mine a little annoying, have to get the knack of threading the wheel bolt through, hanging the spacer on then bolting it to the car.
Posted 24th Oct 2012 at 16:09
my old ones i had for the lions used to be like this i used to have to ballance the 13kg(ish) wheel with my knees hold the non hub-centric spacer on place with one hand but the bold into the wheel brace and then try put it all together! LOL
a proper little balancing act!
hope you find one mate! Smile
Posted 24th Oct 2012 at 16:18
Seems a little harsh, I hope he finds two.
Posted 24th Oct 2012 at 16:20
Two is preferable it must be said.... If not I'll have to front up £40 for a set but the 6 is offroad atm for a coue of months so no hurry. 3mm would also do if anyone has them. (3mm will probably just be correct centre bore no huCool
Posted 24th Oct 2012 at 16:26
LOL you know what I meant!
Posted 25th Oct 2012 at 03:11
calibra306
Didnt think ya could get 5mm hubcentric as the thickness does not require them to be so.
If you use standard 5mm spacers who ever had my car before me used 4 little squares of masking tape to hold them on the hub and despite masking tapes weakness it held for the several time i had the wheels off.
V6 Power!
Faster I can go the better!
Posted 25th Oct 2012 at 05:42
Just get 10mm ones and get them ground down if you can't get 5mm ones!
Posted 25th Oct 2012 at 10:13
T400 PUG Banned!
anything less than 15mm hubcentric wont sit flush on the hub of the 306.
Posted 25th Oct 2012 at 16:01
smegal
You can go down to 12mm safely or 10mm at a push. Anything less won't go over the sticky outy bit that the wheels locate on.
Ex SC-6
Now in a Megane R26
Posted 26th Oct 2012 at 00:13
By sticky outy bit you mean hub craig lol.
Managed to get me a set of these off eBay for £23 delivered. Their an Asian copy of the eibach ones. Their drilled the exact size of the 306 hub canter bore 65.1mm and go straight on with no fiddling. Very good product would recommend to anyone they got sent priority airmail and came within a few days!
Posted 13th Nov 2012 at 09:39
smegal
What thickness did you end up going for?
Lol, gotta love a "technical term".
Ex SC-6
Now in a Megane R26
Posted 16th Nov 2012 at 14:07
5mm mate, took the 6 for a drive with the s**tty 5mm universal ones on and nothing rubbed etc so stuck with that. Got some slightly longer bolts as well as the tiny ones that came with the wheels didn't feel like they were fully in.
Posted 16th Nov 2012 at 14:13
