Author Subject: Wierd braking issues
Alrite chaps,
Seem to have a proper wierd issue with the brakes on my diesel s**tbox. Sometimes when I press the pedal, the ABS goes a bit nuts (feel the kicking in the pedal) and it seems to lock the front wheels up. This seems to happen on pretty light pedal application and only seems to do it within the first couple of times the brakes are used. (if that makes sense).
After it has happened, you can brake as hard or as soft as you like with no issues.
Done it a few times over the last few days, and not had chance to check anything out yet.
Any ideas? Smile
Posted 23rd Oct 2012 at 15:35
Oh yeah sorry, I installed the 310mm brake kit on your fronts while you were asleep, they're a bit ropey when they're cold.
Get some heat into them, they'll be fine.
Posted 23rd Oct 2012 at 16:39
davedgti6
Had this on a Clio, found that a few teeth where missing off the abs rings, abs goes nuts cos it thinks wheels are skidding and abs comes on, after a few presses of the brake pedal it would go away and abs light would go on, check you have no teeth missing, I changed the abs rings (reluctor rings) on the Clio and the problem went away. Don't know if you can just change the rings on a 6 or they are part of the driveshafts? The Clio ones where only £8 each
Posted 23rd Oct 2012 at 17:27
tvrfan007
Cracked abs ring on the drive shaft.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 23rd Oct 2012 at 17:29
Certainly does sound like an ABS ring issue, best thing to do would be to have a quick look for any obvious signs of damage/missing parts.
Posted 23rd Oct 2012 at 19:07
24seven
Yup, had similar on my XS years ago when the ABS ring on the driver's side cracked. Araldited it back in place as straight as I could as a temporary solution be and didn't have a problem.
Posted 24th Oct 2012 at 11:53
Have you investigated this yet Chris?
Posted 26th Oct 2012 at 12:18
Thanks for the replies guys, appreciated Smile
Stan, not checked it out yet, a job for the weekend as I havent really had time during the week. Hasnt happened for a few days though, typical french car having an issue then fixing itself Laugh
Posted 26th Oct 2012 at 12:24
I think that's what we love about French cars, they all go wrong at some point but when they do they fix something else! LOL
Posted 26th Oct 2012 at 12:26
