Author Subject: Heater motor not working
shimmy
Charged the battery on my 6 after it standing for a while and the heater blower won't work, the ac light or other light by it don't work either, any idea did have a little play with the fuses but nothing.
Any idea?
Team V6
Posted 22nd Oct 2012 at 12:11
try the green relay under the dash
Posted 22nd Oct 2012 at 12:24
shimmy
Are the relays all the same, i.e can i try one of the others?
Team V6
Posted 22nd Oct 2012 at 12:28
there are 2 green ones the same which i guess you could swap over, they looked the same to me. i think i did that initially on mine as the first one was all melted at the pin
but you do need both relays. well, my gti6 (p3) did (with aircon)
Posted 22nd Oct 2012 at 12:31
my 306 hdi heater didn't work, think the lights came on though, forget now. anyway after changing the relays and it didn't make any difference. then my mate got in, tried the heater which didn't work, so proceeded to boot the bottom of the heater in the passenger footwell once, for the heater to come back on and hasn't failed since!
Posted 22nd Oct 2012 at 12:46
shimmy
May try that approach LOL could it be the control bit itself as no light come on?
Team V6
Posted 22nd Oct 2012 at 12:54
i'd try swapping the relays over first with a known working good one. mine actually worked by wiggling it for a bit but it was visibly knackered as the pin was melted and stuck into the fusebox in the end
Posted 22nd Oct 2012 at 12:59
shimmy
Still nothing checked relays and they look fine tried a different one aswel and nothing any other things it could be??
Team V6
Posted 22nd Oct 2012 at 20:38
aaron6
It's the relay. It's the green one closest the drivers door. The other are the same. But it'll be obvious if it had it.
Here's my old one with exactly the same symptoms.
Just pop down a scrappy and you'll find one sure.
Posted 23rd Oct 2012 at 13:22
aaron6
If not that maybe a fuse or the controls are shafted.
Posted 23rd Oct 2012 at 13:24
shimmy
Il try the relays again.
Team V6
Posted 23rd Oct 2012 at 17:49
shimmy
No relays and fuses are all fine so could it be the controls?
Team V6
Posted 23rd Oct 2012 at 20:27
fatlapit
i have a spare motor and control unit with ac
Posted 23rd Oct 2012 at 20:36
stop guessing and actually work it out, get the multimeter out, and the haynes manual.
Posted 23rd Oct 2012 at 20:39
shimmy
think the heater motor is okay, do you have a gti6 heater controls?
Team V6
Posted 23rd Oct 2012 at 20:41
fatlapit
yup with
Posted 23rd Oct 2012 at 20:45
shimmy
I wouldn't know where to start LOL do have a Haynes manual though.
Team V6
fatlapit
have u got power going to the motor??? find out which wires do wat and see what feed them n check the feeds for the correct voltage , if you have no voltage work your way to the source until you get the correct voltage. Or work from the source forwards to the same effect simples.
Posted 23rd Oct 2012 at 20:48
did the kicking of the base of the heater in the passenger footwell not work? LOL
Posted 23rd Oct 2012 at 20:56
shimmy
No unfortunately not LOL
Team V6
Posted 24th Oct 2012 at 14:15
LOL
Maybe you ought to turn this into an FAQ mate. Thumbs up
Posted 24th Oct 2012 at 14:48
aaron6
Yes. We'll need a step by step guide. Wink
Posted 24th Oct 2012 at 15:08
306dimma
Sorry I`m maybe little late with my experience, The resistor that sits in the fan motor plate often gives up.
There are different once out there heres one
http://www.ebay.co.uk/itm/PEUGEOU-405-406-PARTNER-CITROEN-ZX-XSARA-PICASSO-HEATER-BLOWER-RESISTOR-644178-/261165757582?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3APeugeot&hash=item3cceb1348e
Leader
Peugeot Sport Club
OF Norway
Posted 13th Feb 2013 at 22:58
Teshboi1988
exactly what happens to mine. why does it melt? cos this is the 4th relay iv had this year thats melted. is there another fault that could trigger it to melt?
phase 3 Hatchback V reg 5Door GTi6
Posted 9th Nov 2013 at 07:58
That's exactly what my phase 2 did a year or so ago. It melted the relay plug as well so had to remove all of it and cut off and re-wire etc. Worked fine since.
First thing I'd do is remove the motor and stick 12v straight accross it.
Posted 9th Nov 2013 at 08:26
