Any idea?
Team V6
| Author | Subject: Heater motor not working |
shimmy
Senior User Location: Shrewsbury Registered: 17 Oct 2009 Posts: 571 Status: Offline |
Charged the battery on my 6 after it standing for a while and the heater blower won't work, the ac light or other light by it don't work either, any idea did have a little play with the fuses but nothing.Any idea? Cheers ________________________________________ Team V6 |
rikky
try the green relay under the dash________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
shimmy
Are the relays all the same, i.e can i try one of the others?________________________________________ Team V6 |
rikky
there are 2 green ones the same which i guess you could swap over, they looked the same to me. i think i did that initially on mine as the first one was all melted at the pinbut you do need both relays. well, my gti6 (p3) did (with aircon) ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
rikky
my 306 hdi heater didn't work, think the lights came on though, forget now. anyway after changing the relays and it didn't make any difference. then my mate got in, tried the heater which didn't work, so proceeded to boot the bottom of the heater in the passenger footwell once, for the heater to come back on and hasn't failed since!________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
shimmy
May try that approach could it be the control bit itself as no light come on?________________________________________ Team V6 |
rikky
i'd try swapping the relays over first with a known working good one. mine actually worked by wiggling it for a bit but it was visibly knackered as the pin was melted and stuck into the fusebox in the end________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
shimmy
Still nothing checked relays and they look fine tried a different one aswel and nothing any other things it could be??Cheers ________________________________________ Team V6 |
aaron6
It's the relay. It's the green one closest the drivers door. The other are the same. But it'll be obvious if it had it. Here's my old one with exactly the same symptoms. ![]() Just pop down a scrappy and you'll find one sure. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
aaron6
If not that maybe a fuse or the controls are shafted. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
shimmy
Il try the relays again.Cheers ________________________________________ Team V6 |
shimmy
No relays and fuses are all fine so could it be the controls?________________________________________ Team V6 |
fatlapit
i have a spare motor and control unit with ac ________________________________________ |
stop guessing and actually work it out, get the multimeter out, and the haynes manual.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
shimmy
think the heater motor is okay, do you have a gti6 heater controls?________________________________________ Team V6 |
fatlapit
yup with ________________________________________ |
shimmy
I wouldn't know where to start do have a Haynes manual though.________________________________________ Team V6 |
fatlapit
have u got power going to the motor??? find out which wires do wat and see what feed them n check the feeds for the correct voltage , if you have no voltage work your way to the source until you get the correct voltage. Or work from the source forwards to the same effect simples.________________________________________ |
rikky
did the kicking of the base of the heater in the passenger footwell not work? ![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
shimmy
No unfortunately not ![]() ________________________________________ Team V6 |
stan_306gti6
rikky wrote: did the kicking of the base of the heater in the passenger footwell not work? ![]() ![]() Maybe you ought to turn this into an FAQ mate. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Yes. We'll need a step by step guide. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
306dimma
Newbie Location: Blaker Registered: 15 Jul 2007 Posts: 26 Status: Offline |
shimmy wrote: think the heater motor is okay, do you have a gti6 heater controls? Sorry I`m maybe little late with my experience, The resistor that sits in the fan motor plate often gives up. There are different once out there heres one http://www.ebay.co.uk/itm/PEUGEOU-405-406-PARTNER-CITROEN-ZX-XSARA-PICASSO-HEATER-BLOWER-RESISTOR-644178-/261165757582?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3APeugeot&hash=item3cceb1348e ________________________________________ LeaderPeugeot Sport Club OF Norway |
Teshboi1988
Regular Location: Dartford Registered: 29 Jan 2012 Posts: 131 Status: Offline |
aaron6 wrote: It's the relay. It's the green one closest the drivers door. The other are the same. But it'll be obvious if it had it. Here's my old one with exactly the same symptoms. ![]() Just pop down a scrappy and you'll find one sure. exactly what happens to mine. why does it melt? cos this is the 4th relay iv had this year thats melted. is there another fault that could trigger it to melt? ________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
aaron6 wrote: It's the relay. It's the green one closest the drivers door. The other are the same. But it'll be obvious if it had it. Here's my old one with exactly the same symptoms. ![]() Just pop down a scrappy and you'll find one sure. That's exactly what my phase 2 did a year or so ago. It melted the relay plug as well so had to remove all of it and cut off and re-wire etc. Worked fine since. First thing I'd do is remove the motor and stick 12v straight accross it. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
