Author Subject: engine management light
bas_306gti
which of the sensors/components of a magneti marelli 1AP10 causes the engine management light to come on?
I'm having a problem with a hesitating engine at low revs and the engine light is on
Posted 17th Oct 2012 at 22:15
Niall
posible from your symptoms is lambda sensor and coolant temp (although im not sure if the coolant temp will bring up the EML. My missus 206 coolant temp sensor went open circuit so defaulted to -40 degrees and that didnt give any warning at all!)
Posted 17th Oct 2012 at 22:25
Sounds like a lambda fault to me. Yes
Posted 18th Oct 2012 at 07:37
last 4 lambda faults I rectified did not give EML.
get it plugged in.
Posted 18th Oct 2012 at 11:37
get it plugged in.
This is true, sometimes faulty lambdas do not illuminate the EML, and getting it plugged in is the correct advice. Yes
Posted 18th Oct 2012 at 14:26
bas_306gti
Tested the system, the 3th injector receives no signal from the ECU, there's no break in the loom and there's 12V on the pin from the fuel/ignition relay. So my conclusion is a fault in ECU itself.....Sad Sad
Has anybody one for sale?
Posted 18th Oct 2012 at 21:02
Rich_W on here sells unlocked ones, it may be of help to you. Smile
Posted 18th Oct 2012 at 22:24
bas_306gti
I'm thinking about what caused the defect ECU, can a temporary short circuit in a injector cause a defect ECU, or is there a build in safety against this?
Posted 18th Oct 2012 at 22:38
Good question, I'm not actually sure on this one. I don't think we've come across the situation before so I would say it should be fine.
I do see your point though, you wouldn't want to damage a second ECU using the same injector if it was indeed dodgy...Hmm
Posted 19th Oct 2012 at 07:15
bas_306gti
The following is from a injection textbook:
"A shorted injector winding causes high current through the injector and the PCM driver this high current may damage the injector driver in the PCM. In some PCM's the injector driver senses high current flow and rather than allawing injector driver to be damaged the shut the circuit off after a cooldown period the injector may allow operation"
So a short circuit in a injector may damage the output unit in the ECU...
I want to be sure I'm not damaging the other ECU so i'm installing another injector
Posted 21st Oct 2012 at 14:57
smegal
Are you sure that the wires to the injectors are ok?
Ex SC-6
Now in a Megane R26
Posted 21st Oct 2012 at 17:20
bas_306gti
Wires are OK, tested zero resistance between injector pin 2 and pin 39 ECU and injector pin 1 and pin 4 fuel relay.
There's also 12V on injector pin 1 when the ignition is on
Posted 21st Oct 2012 at 18:38
bas_306gti
Eventually found out what was wrong...Crazy
There was a cut in a wire to one of the coil packs.
And if the ECU gets no signal back from a coil packs, it shuts of the injection of that cylinder.
Posted 27th Oct 2012 at 23:34
Interesting to know, well done for finding the fault. Thumbs up
So a simple loom fix and I guess it's all running good now?
Posted 28th Oct 2012 at 12:31
bas_306gti
it's running OK now... Smile (after a complete engine rebuild)
It might also be interesting that a short circuit in a injector or in a coil (or in a wire to these components) doesn't damage the ECU immediately as I thought earlier. The injection/ignition (FET) drivers inside the ECU are protected against high currents. See the picture, on the right the injection drivers and on the left the ignition drivers. The steel clamps are for the temperature control (i think).
Posted 28th Oct 2012 at 18:04
