Author Subject: Misfire on start up speedo & rev cntr in 1 o'clock posn
paul171278
Have had a quick search of forum but nothing seems to be similar to my fault.
Just started the car from cold and noticed the gauges doing full sweeps and then stuck at just over 100mph and about 6200 rpm which is when I also noticed the misfire.
Went for a short drive and it went away but then on idle had the misfire and gauge reading again. I assume this is a code for a specific fault. But I have no idea what is.
Does anyone know what this means?
Will do all the usual checks at weekend; plugs, compression test etc...
Posted 15th Oct 2012 at 20:47
gauges going round usually indicate low voltage aka dying battery
Posted 15th Oct 2012 at 20:51
fatlapit
s**tty earth??? Duff battery/alteenator???
Posted 15th Oct 2012 at 20:52
paul171278
Thanks for these replies.
So both are symptoms of a shared problem rather than the gauges indicating a specific fault from the ecu?
Posted 15th Oct 2012 at 20:55
paul171278
Update: just been for a 10 min drive and now constantly misfiring throughout rev range. Sounds like beetle. Does not want to stall but slight petrol smell in car.
Think the AA will be getting a call as all my tools are 100 miles away (bangs head against wall).
Posted 15th Oct 2012 at 21:38
Sounds like a mixture of a dodgy Earth/low batt and a bad coil/plug. Yes
Posted 16th Oct 2012 at 08:14
Matt_rallye
With regards to the clocks, Dum Dum had the same issue recently and it was a duff alternator
Posted 16th Oct 2012 at 14:05
