Author Subject: Radiator Issue
speedo306
Hi,
Every time I fill my radiator and leave the car idling for a little while, water keeps running out of the overflow hose. I bought a new radiator cap being of the view that it was the source of my problem but when I bled the system and topped it back up and carried the car for a drive, on returning home the tank was empty.
What can be a possible cause of this.
RJ
Posted 14th Oct 2012 at 19:55
rob_humphrey
Headgasket maybe ?
Team Moonstone Big grin
Team Working Aircon
Posted 14th Oct 2012 at 19:59
speedo306
Water is not mixing with oil in rad or on oil dipstick. I never ran it to the point where it was overheated.
RJ
Posted 14th Oct 2012 at 20:13
never did with mine, but hg was still kaput.
Posted 14th Oct 2012 at 20:18
speedo306
Seeing that this may be the source of my problem, what do you advise. carry the head to be tested and fit new gasket?
RJ
Posted 14th Oct 2012 at 20:26
bas_306gti
A compression test will clear things out, if there are low readings on one or more cillinders there is a leak to one of the coolant channels or between cillinders, normal compression is about 210 psi
Posted 14th Oct 2012 at 21:30
A compression test as suggested or a 'sniff test' which detects hydrocarbons in the coolant. Wink
Posted 15th Oct 2012 at 09:47
Im not totally convinced mine was mixing really either, If it was it wasnt doing it much, But again kaputt. Between the cylinders too interestingly enough (Not normal for a 6 by all accounts).
Posted 15th Oct 2012 at 10:04
It is actually fairly common for our cars to pop the HG between cylinders. Yes
Have seen it loads of times now. Wink
Posted 15th Oct 2012 at 12:56
yep, there and to a water way on the timing belt end.
Posted 15th Oct 2012 at 13:02
Ah ok, i though it was almost always the water jacket/cylinder area
Wont be going in a hurry now anywho Smile
Posted 15th Oct 2012 at 16:01
It can fail pretty much in any place but the most common are what Welshpug described. Yes
Posted 15th Oct 2012 at 16:11
