I have a hesitance after 5500rpm at which point the engine managment light comes on and then goes out when I drop the revs for the next gear.
I've changed the plugs, coil pack, lambda sensor, MAP sensor and the TPS to no avail.
There is a small black cube looking sensor bolted to the end of the exhaust cam carrier. It has a black wire coming from it that goes to the plug for the coil pack. Anyone know what this is?
I'm determined to get this sorted as other than this little niggle its a spirited little motor.
Thanks in advance.
dan86
what are your plans for it. 205?
