Author Subject: Wing Fitting?
rob_humphrey
Hi guys just wondering how easy it is to fit a new wing are they riveted on?
Team Moonstone Big grin
Team Working Aircon
Posted 3rd Oct 2012 at 00:06
No they are bolted, some are easy like the ones in the engine bay under the edges of the bonnet, others are much more tricky to get at. You will need to remove the plastic wheel arch liner and possibly the bumper too.
Posted 3rd Oct 2012 at 00:12
rob_humphrey
how many are there in total ?
Team Working Aircon
Posted 3rd Oct 2012 at 00:13
darzmat
ive only got rivets under the bonnet holding mine on, with bolts in the wheel arch :S
Posted 3rd Oct 2012 at 00:16
No idea now, keep undoing bolts till the wing falls off is my advice! LOL
rob_humphrey
Probably the best way to approach it thanks mate Thumbs up
Team Working Aircon
Posted 3rd Oct 2012 at 00:19
All I remember is that it helps if you have a long open ended 10mm spanner Thumbs up
Posted 3rd Oct 2012 at 00:29
Mine came as a kit, two bolts each and a bit of wiring and they've been fine ever since Yes
If you find your radio memories reset every time you remove them, you'll want to swap the red and yellow wires.
Posted 3rd Oct 2012 at 08:13
Is it sad that I recognise those wings from a Harrier Jump Jet?
Posted 3rd Oct 2012 at 08:42
Men would say no, women would say yes.
Posted 3rd Oct 2012 at 08:43
russbez
i have noticed the bolts (never replaced a wing before)
isnt there a rivet or two involved under bonnet where wing meets chassis?
My Rallye project thread
Yes there are, you need to drill them out then put new rivets in.
Posted 3rd Oct 2012 at 08:44
rich306
No, cos i do too.
Right, the wing is bolted on as such -
2 bolts behind the door on the car
3/4 bolts on the top underneath the bonnet
i think 1 bolt right on the front behind the bumper. Either way the bumper needs to come off on the side you're working on.
Any sideskirts that are on would be advisable to pull back too.
This is all from memory of doing mine 6 years ago lol.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 3rd Oct 2012 at 08:45
russbez
very helpfull
Posted 3rd Oct 2012 at 08:47
The good thing about removing the wing is it's quite flexible, so it's pretty obvious where any remaining bolts are. It's just a big Mechano kit Yes
Posted 3rd Oct 2012 at 08:52
davewagon
Would this make changing front springs easier, as with the wing out of the way, you don't need to compress the springs so much, and would be able to lean the strut out and clear the arch without having to hammer away at the hub?
Then just remove top cup etc, replace spring and lean back in?
Does that make any sense?
Team: Moonstone GTI-6
Team: Working air-con™
ian7675 wrote:
Posted 3rd Oct 2012 at 09:07
davewagon
But I suppose the added hassle of removing the wing and drilling rivets negates any benefit to doing it that way (unless you were taking the wings off for another reason anyway)
Posted 3rd Oct 2012 at 09:08
I think the arch liner would still be in the way, if you got rid of that too then yes it'd probably be much easier.
Posted 3rd Oct 2012 at 09:09
Much easier to drop the lower bj and whip off the whole strut.
Posted 3rd Oct 2012 at 09:19
That's what I've always done.
Posted 3rd Oct 2012 at 09:20
rallyecomms
I just replaced a wing at the weekend there. there was 1 rivet on the top of the wing, which i just drilled out. the rest was all bolts. 2 on the top easily accessible, 2 behind the indicator which you need to take the bumper or slam panel off for, 2 between the drivers door and the wing and 1 just under the edge of the sideskirt.
I didn't need to remove the sideskirt, when using a ratchet spanner. By far the most awkward bolt was the top one, on the inside of the wing at the drivers door. Needed uber long extension bars to get at it.
Road Rally car - Manstone Ph3 GTI-6. Quaife ATB, hydraulic handbrake, OMP Cage and loads of other rally crap!
Rally Car - Ford Olympic Blue!. Quaife ATB, hydraulic handbrake, Safety devices cage, GpN Pug Sport kit!
Posted 3rd Oct 2012 at 09:23
the slam panel doesn't have to come off, you can get the wing off just by undoing the bottom bolt under the wing and it slides out. that only traps it in place IIRC and accessible from underneath with your head in the arch liner. i think you can just undo the slam panel corner bolt and it'll prize up. saves taking the full panel off for sure
as above though - couple of bolts on the top, two on the inner edge at the door (use long xt bar), and the rivet at the top which may need drilling out. then one in the bottom corner of the sideskirt accessible from underneath with a torx driver. plus probably chopping some sealant but still - skirt and slam panel can stay on
Posted 3rd Oct 2012 at 15:34
