Author Subject: BE3 conversion to cable change
stuart638
Has anyone done this?
I'm looking into doing away with the gear rods and changing to bowden cable operation. I know there are a few Peugeots & Citroens that have cable change, but am interested to know how easy a BE3 box would be to adapt?
The reason being, that I am looking at the possibility of changing to a sequential shift for next season, but the shifter will only work with a cable operated gearbox.
Posted 2nd Oct 2012 at 16:00
crossflow
I have done this to our race car I can supply a full kit if you want comes with everything needed, here incar footage of the car but you can clearly see the gear change on it
Posted 2nd Oct 2012 at 16:35
stuart638
No video!
What kit is it?
Posted 2nd Oct 2012 at 16:42
easy enough to get a shifter from something like a 307 C4, picasso etc, swap the bits on the gearbox pop a hole in the bulkhead for the cables and make something to bolt the lever down to.
Posted 2nd Oct 2012 at 16:48
stuart638
This is what i'm looking at for the gearbox
Posted 2nd Oct 2012 at 17:06
yeah you can get much less shiny examples like that from a standard vehicle.
Posted 2nd Oct 2012 at 17:11
jonnie205
206 gti 180 would donate the right bits
Posted 2nd Oct 2012 at 17:15
stuart638
Perfect, thanks for your help guys. A trip to the breakers is in order then!
Posted 2nd Oct 2012 at 17:17
stuart638
So, do all the cable change cars have the same setup on the gearbox?
Posted 2nd Oct 2012 at 17:24
jonnie205
i have a 180 setup if you want?
Posted 2nd Oct 2012 at 17:25
no, as many are ML gearboxes which would not be compatible, neither would the matching cables, they need to be from one vehicle afaik.
sounds like Jonnie can sort you out anyway.
Posted 2nd Oct 2012 at 17:32
Hawkesfire
Hi Jonnie
Have you still got the gti 180 set up for sale as i have tried to PM you but it says you have no access
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 5th Sep 2013 at 09:49
