Author Subject: Front power steering cooling pipe brackets
mik
I'm looking for the 2 brackets that attach the power steering cooling hose to the cross-member under the radiator.
Mine are bent, seized and look as though they came off the Titanic and I can't get them undone despite many hours with release fluid etc. Due to bending I can't even get the torx bit into one of the bolts so probably have to cut/drill.
I'll need some to install the nice new pipe I've got. Anyone got some in reasonable not-too-rusty condition?
Ta.
Cherry Rallye SOLD
Posted 1st Oct 2012 at 19:16
c_j_m
Surely there cheap enough from pug?
Posted 1st Oct 2012 at 19:28
mik
Yeah, would have been but one is NLA - can't remember which one. Have ordered available one but will need other one as not optimistic about salvaging one of mine. Might see whether I could just have 2 the same to avoid NLA problem.
Still after these if anyone has decent ones.
Cherry Rallye SOLD
Posted 1st Oct 2012 at 20:39
rubber lined stainless P-clips ftw.
Posted 1st Oct 2012 at 20:48
scotzman
they are both the same and yes, NLA, i just had to clean mine up.
you can still get the plastic parts, maybe thats what you ordered.
Posted 2nd Oct 2012 at 11:45
mik
The plastic parts (missing from my car) and the 'top clamp' (if you know what I mean) pieces are available and ordered, but the bits that these attach to, which in turn bolt to the chassis cross member are NLA.
F**k knows how I'm going to get these off. Hacksaw + drill + heat I think. All I need to salvage is the bits that screw to the cross member.
Unless anyone has any?
Cherry Rallye SOLD
Posted 2nd Oct 2012 at 20:10
scotzman
Drill out the Torx screws starting with a tiny drill bit and gradually work your way up in size, do it carefully and you should get them out without damaging the threaded part in the crossmember, that's how I got mine off.
Posted 2nd Oct 2012 at 20:29
fatlapit
I will look at work 4u
Posted 2nd Oct 2012 at 20:31
mik
Thanks guys.
Cherry Rallye SOLD
Posted 2nd Oct 2012 at 23:30
mik
Still looking for these...
Cherry Rallye SOLD
Posted 8th Oct 2012 at 18:07
mik
After a lot of release fluid, blowtorch heat and swearing, I've managed to reclaim and straighten my bent rusty brackets, so the request in this thread is no longer required.
Cherry Rallye SOLD
Posted 12th Oct 2012 at 19:29
I thought you could just loop that pipe around when It goes as it does f all??
I.e just attach inlet to outlet in the shortest way possible
Posted 12th Oct 2012 at 20:22
So you think the pipe is like that for no reason ? Or maybe it's like that to aid cooling the fluid ? Dunno
Posted 12th Oct 2012 at 20:36
scotzman
Does pas fluid actually get hot? Just the other day I was wondering if this pipe could be done away with.
Posted 12th Oct 2012 at 20:39
Yup it certainly does - any fluid under presure will heat up I think ? That's why water is no good as it boils and produces a gas which is bad
Posted 12th Oct 2012 at 20:48
Im sure i read only yesterday something in someones project thread about how it does f all.... Something like you can keep a bit of it too help you loop it around etc etc...
Posted 12th Oct 2012 at 20:49
Backtracked my ie history.
Its in lynx garages sc kit install guidelines.
Basically you can keep a bit to join it up the the flexible hoses.
Posted 12th Oct 2012 at 20:57
Well yes technically it doesn't do a lot other than allow fluid through it but I pretty sure it aids cooling due to its location ?
I'm sure pug put it there for a reason other than to go rusty LOL
Posted 12th Oct 2012 at 20:59
If all the supercharger conversions (i assume) have it done i doubt its an issue either :p
A few sc conversions have pas coolers though i suppose....
Posted 12th Oct 2012 at 21:01
