Author Subject: Engine
moxigti6
Hi
I have a gti6 with a running issue, it is over fueling to the point where it chugs along almost like it misfiring only under 2000rpm and also dumps fuel in the engine oil, also has a low manifold vaccum its around 500 m/bar just over, I have so far changed-
Injectors (cleaned/filters/o-rings)
Inlet/throttle body gasket
Engine temp sensor(green one)
Fuel pressure reg
Plugs
Lambda sensor
Timing belt
Crank pulley
Flywheel
Map sensor
Coil packs
Throttle position sensor
Speed sensor
Crank/cam sensors have been checked and seem to be working
If anyOne has had the same problem please help
Moonstone gti6
Posted 30th Sep 2012 at 18:18
is it black?
Posted 30th Sep 2012 at 18:19
darzmat
is there need to have 3 posts exactly the same in one day?
Posted 30th Sep 2012 at 18:20
moxigti6
Don't no what the 3 post are about iv only posted it once lol it's moonstone
Moonstone gti6
Posted 30th Sep 2012 at 18:21
i have a feeling theres a fundemental bodge going on, or something like the lambda is stuffed even though its new
Actually try unplugging the pas sensor too, as the chugging could just be that its faulty and not compensating for the pump.
Posted 30th Sep 2012 at 18:23
darzmat
moxigti6 wrote:
it's moonstone
thats your problem, get a respray and all your engine troubles will disappear Wink
Posted 30th Sep 2012 at 18:24
moxigti6
I wish it was just a bodge goin on would be easier to fix ha I did wonder if it was the lambda but when viewed on live data looks to be doing its job
Moonstone gti6
Posted 30th Sep 2012 at 18:27
btw i would just delete the other threads in engine as you have responses here now and it will just get busy and hard to keep track of otherwise.
Posted 30th Sep 2012 at 18:28
moxigti6
I think iv managed to delete the others:-)
I'm new to the messaging n all that iv only ever read through the forum
But car problems made me have to pay the fiver haha
Moonstone gti6
Posted 30th Sep 2012 at 18:37
Moved to Engines. Smile
Posted 30th Sep 2012 at 18:42
moxigti6
Elliotrw only just read the part about unplugging the pas sensor will try that 2moz cheers mate
Moonstone gti6
Posted 30th Sep 2012 at 20:21
bas_306gti
low vacuum,
is this a steady value, or is it fluctuating?
Posted 30th Sep 2012 at 20:49
LOL
Don't worry, I've deleted them for you...Wink
Posted 30th Sep 2012 at 21:25
moxigti6
Cheers mate and it is a steady vaccum no fluctuation atall
Moonstone gti6
Posted 30th Sep 2012 at 22:17
moxigti6
Forgot to say also when viewing the live data my injectors are open for 3.7 m/s when viewing my friends 6 they were open for 3 m/s this was on idle, someone did suggest a break in the loom what do you all think?
Moonstone gti6
Posted 30th Sep 2012 at 22:40
moxigti6
Moonstone gti6
Posted 1st Oct 2012 at 07:44
bas_306gti
There can always be a cut in a wire, especially the wires to the coil packs because these get hot
You've got to check with a multimeter every pin on the ECU with is corresponding pin in the loom.
For instance pin 1 connector MAP sensor = pin 41 ECU
Posted 1st Oct 2012 at 11:34
