Author Subject: What are these bolts called!!!
Tallguy_2
Just finishing off the belts etc, on my harness I have solid bolt through points at the end of each strap, I don't have the ones you can clip onto an eyelet, where the two rear seat belts come out they had a type of bolt that I reused, it has a collar meaning that the bolt is pinched tight but the harness mount can still move and isn't pinched tight between the bolt and the mounting plate/body original mounting points
If anyone knows what these are called or where I can buy them I'd be most grateful
Thank you
"winners come and go but legends never die..."
autorite-sport.co.uk
Posted 30th Sep 2012 at 01:33
pete_rallye
should help-
pete_rallye has attached the following image:
Lap of the 'ring
Posted 30th Sep 2012 at 01:51
pete_rallye
or at least it would do if I could get it to a decent size... anyway, part numbers are 8978L7 FOR A 10mm spacer, 897115 for a 6mm spacer, 8978H2 for a 18mm long bolt, 897114 for a 25mm bolt and 897885 for a 20mmlong bolt. All the bolts have a non threaded section to take the spacer, so it remains 'loose' whilst its all done up tight. If you pm me your e-mail I can send you a decent sized picture...
Lap of the 'ring
Posted 30th Sep 2012 at 01:56
Tallguy_2
Just pm'd, thank you very much, I guess just go and order from pug? Or if anybody's breaking one?
Posted 30th Sep 2012 at 11:43
Scrapyard ?
Posted 30th Sep 2012 at 11:45
Tallguy_2
Mr S lol!
Your strut brace is on dude! Bolt the belts in and she's ready for the road this week!
Posted 30th Sep 2012 at 11:54
