Author Subject: aircon pump removal
daytime6
as above,just fitted my rallye set up today (not a bad job then i thought it was guna be) and was wondering how every one whos witched over has managed to get there air con pump out?
Posted 29th Sep 2012 at 20:38
4 bolts - undo them and it comes off ?
16 mm I think
Posted 29th Sep 2012 at 20:39
16 mm I think
Yes
Posted 29th Sep 2012 at 20:53
mattgti6phase2
2 of them are a bit of a pain to get to, the top 2 iirc but it's an easy enough job.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 30th Sep 2012 at 00:31
daytime6
That's what I'm having trouble with as got the bottom ones off just a pain to get the top ones off,any one have any tips or guide on how you got the top bolts out
Posted 30th Sep 2012 at 01:26
Just patience and small movements with the spanner. Yes
You'll get there but, yes they are a bit of a PITA. Wink
Posted 30th Sep 2012 at 09:05
daytime6
think thats what im guna have to do,but shall all be worth it in the end tho
Posted 30th Sep 2012 at 09:56
It is a lot easier to get them off if the front of the car isn't in place, but it's a bit overkill if you remove the front end just for that purpose. LOL
You'll do it, it may help if you manage to obtain a shorter 16mm spanner than standard then you will have more room to move it once located on the bolts. Yes
Posted 30th Sep 2012 at 11:49
daytime6
Like a stumpy 16mm spanner yeah?,was thinking of takin front end off as wanted to do abit of restoration work on the front end
Posted 30th Sep 2012 at 12:13
parrotno1
Have you got other bits of the air con? Would you sell
Posted 30th Sep 2012 at 14:41
daytime6
I've only got the air con pump as I had a front ender an the rad got damaged,all the pipes are ok ,what you after?
Posted 30th Sep 2012 at 22:23
