cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD
Black p3
| Author | Subject: 1st blast in the new 6 |
swiftyboi006
As some of you may now i used to own a cherry p1, handled very well indeed lowered with strut brace ect. Just got the blaze through the mot what made me happy so i thought id give it a test with an mg zs that a couple chavs wer driving, got to a nice road and goodbye runs sweet as a nut. The engine runs better than the p1 (rebuild 20k ago) but the handling isa bit rear end happy. Would lowering with just front springs and strut brace help this? Dnt want to spend out as its been cheap so far________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
aaron6
No. It's probably the rear beam mounts getting tired. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
playboyb
Seasoned Pro Location: Maidstone Son! Registered: 27 Jun 2011 Posts: 1,464 Status: Offline |
Sounds like the beam mounts, get some solid mounts on there unless you like passive rear steer, in that case new pug mounts will do the trick ![]() ________________________________________ 306 1.8 xs moonstone blue-SOLD306 gti6 supercharged china blue-SOLD 406 coupe D9 3.0 V6-SOLD |
aaron6
Passive mounts ftw!________________________________________ See the sheer power and might of the lesser known burrowing owl. |
swiftyboi006
Rear beam mounts are new ![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
balljoints / front suspension?________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
swiftyboi006
Just changed the p bushes everything else is fine just passed mot. Wen i can be assed ill get the beam off to lower it and have a proper look at the mounts but im pretty sure they wer new________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
aaron6
Ovalised hub on the front?________________________________________ See the sheer power and might of the lesser known burrowing owl. |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
Id be looking at TyresDo you have better on the front? Pressure right in them etc? Either that or seeing as you said just passed mot I'd say its more likely tired front suspension, they will only check for play and rebound on the test usually so won't show up if they've gone a bit soft. ________________________________________ Ryan |
swiftyboi006
Its the rear of the car tho? ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
aaron6
I know that front suspension issues can cause the tail to feel loose. Maybe your new rear bushes are too soft. Were they pug one's? Probably front suspension or p**s poor tires. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
swiftyboi006
Will have another look once i get time there all good tyres on there apart from the frots are a bit worn. Mite get some new mounts for the rear anyway if the beams coming off________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
aaron6
Get the pug ones. If you wanna save cash get the solids from miles. I don't know why but the rubbers are dear. Worth it though. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
ryangti6
swiftyboi006 wrote: Will have another look once i get time there all good tyres on there apart from the frots are a bit worn. Mite get some new mounts for the rear anyway if the beams coming off Above you said the rear mounts are already new... I know you said the rear is the problem but if the front is tired and the back is all tip top with new mounts etc you will have lost the balance in the car and if the back is stiffer/tighter it will make it want to lose grip before the front. What I meant with the tyres is more brand/quality than actual wear (unless you have 4 matching tyres). If you've got something like Michelin on the front and Nankang's on the back then your car will behave like you are describing, if they are all the same and the front are significantly more worn then it could be worth swapping them around and see if it's better. ________________________________________ Ryan |
swiftyboi006
Cheers for the help________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
