Author Subject: P202 EUT (phase one or two?) locking problems
jimmyhackers
my car is a P reg, it has the phase one front bumper, a phase 2/3 "stealth" parcel shelf, and the fatter iIR keyfob from a phase 2. i know peugeot liked to use any old parts on the assembly line.
so im wondering if this is a normal or wether ive had someone in the past modify/tinker with the car.
this seems the more likely option as i bought the car and had to rescue it from lexus lights and the naffest rear spoiler amongst a few other things
break calipers, fooked paint etc etc etc
to set the scene, the cars been sat (angled upwards) on my drive for a while, the remote central locking worked perfectly, even after 3 or 4 completely flat batteries all id have to do is charge it up and everything was grand again.
i moved (under its own steam) the car onto ramps under the front wheels. so its now angled downwards on my drive.
i then central locked/deadlocked it all up. left it for a while, came back to the battery being flat again but this time after charging it the remote part of the central locking didnt work. replacing the battery with a working one didnt make the remote locking work either.
after finally getting in after thinking it'd permanantly locked me out (turned the key that extra undeadlock rusty click) and i got in. the central locking works. just not the remote part now.
also, to my annoyance, the alarm trips itself regardless of keys being in or ignition on/engine on.
the sunroof leaks so i assumed changing the car from facing it upward to facing it downward, meant the leak water has messed up the central locking box under the driver seat.
BUT ITS NOT THERE!!! hence me asking "is it a phase one or a two?" where else should i look, i still think its water damage but im unsure where to look. where are the central locking components located. i know that the IR reciever is in the roof centre console, but is the box i thought was under my seat hidden somewhere else on later models?
sorry bout the longwindedness of this post
any help would be appreciated
james
Posted 28th Sep 2012 at 14:59
smithers
Have you tried reprogramming the remote fob to the car?
The fact that your main battery was dead has probably killed the backup batteries in the siren hence why it's going off all the time.
1997 Black GTi6
smithers205 at hotmail.com
Posted 28th Sep 2012 at 15:07
gilesy
Sadly the car is equipped with a mercury tilt switch as used by the IRA. I'd examine it for that before going any further
Posted 28th Sep 2012 at 15:34
jimmyhackers
thanks for the help. ill get on to me brother shamus about the mercury switch
whats the method again. turn the ignition on and press the keys button for a few seconds?
and the siren batteries? im guessing the sirens under the front arch left/right?, is that where the batteries are? what size are they?
Posted 28th Sep 2012 at 17:07
smithers
The siren batteries are sealed within the siren itself - have a search for Siren - plenty info and general consensus is that it is easier to replace with a known working siren.
Programming phase 1/ 2 keys below:
smithers has attached the following image:
1997 Black GTi6
Posted 28th Sep 2012 at 18:21
jimmyhackers
ive only got one key, so i guess ill be dismantling it.
does my siren/battery need to be working for the remote part to work/sync?
thanks for the info, ill try that out tommorow.
Posted 29th Sep 2012 at 03:10
The siren doesn't need to be working in order for the key fob to work with the car. Wink
Posted 30th Sep 2012 at 11:53
Also, you should easily be able to tell if your car is a Phase 1 or 2.
Is it a pre-facelift model? (Non-colour coded bumpers, squarer headlights etc.) If so, it's a Phase 1. Do you have an oil PRESSURE gauge on the dash? If so, it's a Phase 1. Wink
Posted 30th Sep 2012 at 18:46
c_j_m
Remote locking box is under the drivers side rear seat tucked right up out the way.
Posted 30th Sep 2012 at 19:05
jimmyhackers
its a phase one, (oil pressure gauge) cheers for the help so far
ive just tried all of said methods to reprogram my key fob. none of them are working : S
the fob itself is still working (checked infra red light on it with phone camera) i also tried it with the cover removed from the infra red sensors to make sure the signal/lights is definately getting there.
all ive down is turn the car round on a slight slope. so its gotta be the IRA mercury tilt switch or some body of water has sploshed onto something and fooked it......if you have any other ideas then please let me know
im at a loss here........ i can see no obvious or even minor signs of water damage on the roof center console,
the remote locking box, is it the one under the driver side rear seat where your ass would be. or is definately behind the rear driverside (non-door card) likewise both of these show now signs of moisture/water damage
despite getting screwed on price, if i went and bought new said boxes from mr peugeot parts. is it a case of plug and play or will i have to get them "matched" etc
on i side note with the plug and play question, does that also count for a brand new blank keyfob?
thanks again for the help guys
Posted 13th Oct 2012 at 17:01
Niall
with the ph1, things are pretty much plug and play with the exception of the ecu and bsi which is located below the hazard light switch (pretty sure ph1s have these?)
Posted 13th Oct 2012 at 21:48
under the dash on the p1 you have the airbag ECU and sometimes the keypad immobiliser, nothing else
the cl box is in the rear quarter on the drivers side I believe
Posted 13th Oct 2012 at 21:52
boost
have you tried the wires in the door they are prone to breaks ? and did ph1s have oil pressure gauge and ph2&3 have oil temps ?
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 13th Oct 2012 at 21:59
yes p1 had pressure and level as a double functioning gauge
Posted 13th Oct 2012 at 22:00
boost
ahh a didnt know that thanks haha a just thougjt they all did level and temp
Posted 13th Oct 2012 at 22:02
boost
by the way did the xsi 16v have the level and temp too or just temp ??
Posted 13th Oct 2012 at 22:03
not sure tbh, I just know from my p1 xsi (r plate!), I imagine the p2 just had level and temp
Posted 13th Oct 2012 at 22:10
Niall
Ah ok then. In which case that ecu behind the rear quarter may need to be coded. The immobiliser chip isnt memorised by the ECU. It just receives a yes or no from the bsi.
At least thats how it is on the ph2 and 3 and iirc they share the same ecu dont they?
Posted 13th Oct 2012 at 22:17
Niall
ph3 didnt. Just had standard petrol dials with a oil level gauge. No temp.
Posted 13th Oct 2012 at 22:18
boost
see i thought the xsi only had level ? n only the gti6 n ralley had level and temp
Posted 13th Oct 2012 at 22:22
miles
The keypad has nothing to do with the Alarm in the rear Qtr panel,
The problem is it's IR and not RF, you need a matched pair from new as they cannot be programmed , plus normally water get's into them and corrodes the terminals off in the roof consul part
www.pugracing.com
Posted 13th Oct 2012 at 22:48
jimmyhackers
thanks miles,
ill get my electrical hat on tommorow and crack out the pcb-fix pen Smile. have a proper proper rummage about. its gotto be water damage somewhere ive missed
Posted 14th Oct 2012 at 01:15
miles
Could be the Door loom, Receiver, Control box, bad connection somewhere so good luck
www.pugracing.com
Posted 14th Oct 2012 at 01:46
rich306
There was a box located behind the drivers seat under the rear bench related to the central locking on my ph1.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 14th Oct 2012 at 02:14
gilesy
Jimmy hackers now has his Area 51 head on....
Posted 14th Oct 2012 at 02:28
