Author Subject: Oil pump refurb/rebuild
clen666
Is there a guide anywhere showing how to refurb an oil pump, and what parts require replacing?
Team 'unintentional rat look'
Posted 24th Sep 2012 at 19:40
Pug pumps don't usually require any work at all, but there are checks you can do detailed in the Haynes manual.
Posted 24th Sep 2012 at 19:55
matt evans
if theres been a drop in oil pressure enough to make the bottom end rattle, would you not strip and rebuild the pump then Mei or simply replace with a new one?
honestly3k wrote:
owain wrote:
Posted 24th Sep 2012 at 20:08
pete_rallye
They hardy suffer any wear whatsoever, not unless they have picked up a load of crap, but even then it's minimal as big chunks are filtered out by the gauze. There pretty easy to strip down, inspect and clean, and then put back together. Just undo the bolts, (mind the spring doesn't smack you in the face) record the order the bits come apart (there's not many) and then clean them all and put it back together.
The only part that needs replacing is the metal gasket, but quite a few I've had haven't had it fitted. I'm not sure if theres a difference between them all, but if yours has one, replace it, if not, don't!
Lap of the 'ring
Posted 24th Sep 2012 at 20:21
Rich E Forum Admin
There's nothing in the pump that can't be cleaned and serviced and you get a replacement oil pump gasket in the engine gasket kit, so there isn't a need to default to replacement.
edit: Beaten to it by Pete.
Posted 24th Sep 2012 at 20:23
clen666
Thanks for the replies guys.
Have an engine gasket kit sitting in the cellar, will have to hunt it out and check it has one for the oil pump as I don't recall there being one Unsure
Just thought I might as well get it tip top whilst it's out of the engine
Posted 24th Sep 2012 at 20:36
As has been mentioned, the pump itself will rarely be the cause of an oil pressure drop, that's commonly worn engine bearings, or low oil level/surge/starvation etc.
Posted 24th Sep 2012 at 20:37
pete_rallye
If you need a gasket let me know, the last engine gasket kit I bought had 8 of them in it LOL
It certainly doesn't hurt cleaning them, some of the ones I've had have been quite manky inside, just never had to replace one, or any parts in them.
Lap of the 'ring
Posted 24th Sep 2012 at 20:41
clen666
Assuming this is the gasket for the oil pump?
Also, what is the following lube intended for? Head bolts?
Posted 24th Sep 2012 at 20:58
thats the bugger.
Posted 24th Sep 2012 at 21:07
pete_rallye
Yeah, lubes for head, main and big end bolts so you get a correct torque reading.
Lap of the 'ring
Posted 24th Sep 2012 at 21:26
clen666
Cheers Pete, thought so just better to check before whacking it on!
Whilst on this topic, I'm using ARP rods bolts, would it be better using the lube from ARP or will it just be more or less the same?
Posted 24th Sep 2012 at 21:33
pete_rallye
From what I can gather they are all molybdenem disulfide based so probably more or less the same stuff. After doing a bit of research it seems its the same stuff you can use on bearings/cams etc as assembly grease anyway...
Lap of the 'ring
Posted 24th Sep 2012 at 23:08
clen666
Thumbs up thanks mate
Posted 25th Sep 2012 at 11:18
