displaying posts 1 to 2 of 2
Author Subject: Fitting hybrid arb
jbradders
Do the end plates just slide on or do they need a whack?
On the old one they just slide over the splines but on the hybrid they will only go on a bit.
Thanks
Posted 20th Sep 2012 at 11:47
Drill and tap the ends to M8, as they really should have been at the factory...
Then fit the nearside end plate and pull it fully on the splines, this is the fat end IIRC, then with the right hand end plate place a 1mm feeler blade behind the end plate and tighten it down.
Also before doing all that, you need to make sure that the end plates fit on the right splines, otherwise you'll throw the ride height out and make it handle odd.
Posted 20th Sep 2012 at 12:03
