Author Subject: cam timing
JWP EFi
Turbo Legend!
how many degrees - at the crank can i safely go before i risk bent valves?
Posted 5th Sep 2012 at 21:46
At the crank, probably about 4 deg. As this would translate to 2 deg at the cams as they turn at half the speed of the crank. Wink
Posted 5th Sep 2012 at 22:30
JWP EFi
Turbo Legend!
yea, i know cams run at half speed!...4 degrees, is this for both inlet and exhaust?
Posted 5th Sep 2012 at 22:34
Why do you ask ?
Posted 5th Sep 2012 at 22:41
JWP EFi
Turbo Legend!
bigbadbowen wrote:
Why do you ask ?
..thought there was 10 more bhp and lb ft to be had by advancing timing.
Posted 5th Sep 2012 at 22:45
24seven
There's talk of it bringing the power band slightly down in the rev range if you advance the inlet cam by a couple of degrees making the power more "useable", but I don't recall ever seeing any charts or dyno runs done to prove this. It's one of those things that can ruin your engine if you muck up trying to set it up and there's very little room for error on these engines, so to be honest, I'd just leave it alone.
Posted 6th Sep 2012 at 00:49
Whilst it can be done, ^^ this is the best advice if you don't want to risk internal damage. Yes
Posted 6th Sep 2012 at 07:57
docwra
It made a noticable difference on mine. Twice in fact. But I cant tell you how much you can safely go as I didnt do it myself either time, sorry Smile
Lots of Nissans, two 306 GTI-6's. They are catching up! Big grin
Posted 6th Sep 2012 at 18:00
I remember Petegti6 doing this back in about 2007, and he gained about 10lb/ft from doing it. Yes
Like docwra says, it can be done, but you've really got to know what you're doing otherwsie the engine will go bang. Yes
Posted 6th Sep 2012 at 21:12
JWP EFi
Turbo Legend!
so 2 degrees on inlet? i'll try it out this weekend, if i goes pete tong then ive got 3 spare heads/engines so got to
be worth a bash, gain of 10 ft lb is a worthy profit considering it wont cost me anything....hopfully
Posted 6th Sep 2012 at 22:19
If you've got plenty of spares and don't mind a bit of trial and error then go for it. Thumbs up
Are you looking to get it on the rollers after to see what sort of difference it made or just drive it and see if it 'feels' any better? Dunno
Posted 6th Sep 2012 at 22:26
JWP EFi
Turbo Legend!
when i bought the car couple weeks back it had decat and magnex, i planned to dyno it before i put cat back on,
ive put full o/e system back on so ideally i'd like to advance cam then dyno it followed by second RR run with
decat/magnex.
i'm assuming 10 ft lb will be fairly noticable out on the road
Posted 6th Sep 2012 at 22:30
Fair enough, you should be able to feel the extra 10lb/ft on the road assuming you manage to gain that figure. Smile
Posted 7th Sep 2012 at 12:35
you may not feel it really, as it makes it smoother losing the "kick" people say they feel in ones with the timing retarded.
Posted 7th Sep 2012 at 12:56
By doing the mod, it is supposed to bring the peak power down further in the rev range, so there becomes little point in going over the 6.5k etc.
Posted 8th Sep 2012 at 10:47
