Author Subject: Help.. Bosch MP3.2 remapping
peugeot96
Can anyone help with renapping of a MP3.2 ecu. Is it best to use TPS or MAP or both. Running ITBs so l dont have good vaccum. The engine was on the rollers but is to rich low down.
Posted 4th Sep 2012 at 18:43
if on itb's then don't use MAP for load, use TPS
useful to have pressure sensor for barometric correction apparently but that's about as much as I know! (i.e to correct for air density changes like you get between sea level and high mountains)
Posted 4th Sep 2012 at 21:37
peugeot96
Thanks againThumbs up
Going back to the rollers on friday. l think the mapper used both TPS/MAP last time it was mapped but the engine is running to rich down at low RPM. Talked to Wayne Schofield on the phone for some time ago (very helpful man).He told me he could assist my mapper over the phone. But l dont have a heart to disturb him.
Posted 4th Sep 2012 at 22:04
mabgti
NV motors
Need a bit more info... Engine? Injectors? Compression?
TPS should be main load factor. low down richness can be dealt with fuelling easy enough
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 4th Sep 2012 at 22:34
JWP EFi
Turbo Legend!
forgive me for being thick but am i reading this right?...ITB's with bosch ecu, tell me more
Posted 4th Sep 2012 at 22:43
peugeot96
2.0 mi16 engine. Cams,11.1 comp , bosch bluetop injectors 250cc and throttle bodies.
Posted 4th Sep 2012 at 22:54
