Author Subject: Side skirt fittings
chris with a pug
Just been on the phone to peugeot to order the bits to fit my side skirts.
I have ordered the 22 rivets and the 6 clips part numbers 6970-34 and 6995-h2 respectively, the problem is the stick on clips 6995-p6 are no longer available, does anyone know of an alternative that might fit or where I might be able to get something similar?
Thanks
Posted 30th Aug 2012 at 12:03
bellcp306td
i think i have 2 in my tool box if you want them?
Where did the road go!
Posted 30th Aug 2012 at 12:54
Thanks
Big blob of Tiger Seal/PU Sealer and some tape to hold it to body nice and tight while it goes offThumbs up
Posted 31st Aug 2012 at 22:17
Stick on clips are s**t anyway sealant it.
Posted 31st Aug 2012 at 22:41
chris with a pug
but they are sealed as standard!
Might as well get a clip if i can
Posted 31st Aug 2012 at 22:53
mik
A PO put dome-headed screw at the rear wheel arch lip through the rear of the skirt but only on one side. Looked factory as head recessed into skirt, except it was not done on other side. So I've duplicated it so it is the same both sides and replaced the screws with stainless painted back.
Haven't had skirts off yet but am guessing it was done due to missing one of these clips, so skirt didn't sit flat against car at top edge.
Cherry Rallye SOLD
Posted 1st Sep 2012 at 11:16
The ones I've removed haven't been unless they've been replaced after a milk float incident.
Posted 1st Sep 2012 at 16:41
