displaying posts 1 to 25 of 40
| Author | Subject: 5door gti6? |
rallye1999
Senior User Location: redcar Registered: 05 Jul 2009 Posts: 722 Status: Offline |
I've aquired a 5dr phase 3 with a poorley engine and I still have my enging, gearbox, shafts, steering, brakes, fuel tank and pump, radiator pipes, clocks etc, what else will I need gti6 specific, I'm just doing it out of boredom really |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
It will certainly surprise a few people that will think it's a lower spec 306 ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
rallye1999
It's a beautiful British racing green too |
Matt_rallye
Regular Location: Bournemouth Registered: 09 Jul 2012 Posts: 468 Status: Offline |
Was going to ask if it's Diablo, my mate just got rid of his lol |
mattgti6phase2
I actually quite like that colour in a weird way. Reminds me of alpine forests, and the green tree air freshners that smell of alpine forests ![]() ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
stan_306gti6
I always thought they should have made a '6' in that colour. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rikky
unlucky colour ![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
if it was petrol then all is fine, crack on.if it was a diseasel you'll need to swap the tank and all the lines, possibly some wiring. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rallye1999
welshpug! wrote: if it was petrol then all is fine, crack on. if it was a diseasel you'll need to swap the tank and all the lines, possibly some wiring. So basicly engine out, swap the rack, engine exhaust brakes suspension etc plug the loom in swap my unlocked ecu, fuel pump and im nearly there |
c_j_m
Seasoned Pro Location: Andover Registered: 23 Sep 2007 Posts: 1,917 Status: Offline |
Matt I've got Sams old car.As for the conversion, you'll need the same phase engine bay loom, and the fuel system from a 6 (well on the 1.4 we did a xu doner may be different) along with the clocks and that should get it running with a unlocked ecu. |
rallye1999
c_j_m wrote: Matt I've got Sams old car. As for the conversion, you'll need the same phase engine bay loom, and the fuel system from a 6 (well on the 1.4 we did a xu doner may be different) along with the clocks and that should get it running with a unlocked ecu. cool, still got my loom |
c_j_m
Actually that reads a tad wrong, you need the same phase engine bay loom as the car its going in.As the one I've got originally had a ph2 (in a ph3 car) and the lights, speedo and a few other things didnt work till we swapped in a ph3 loom, also saves messing with the abs loom too then. |
Ed_van_dijk
Senior User Location: Halesworth Registered: 10 Jan 2007 Posts: 636 Status: Offline |
Depending what wheels you are running, you should get away with not changing the rack.________________________________________ Astor 6 |
ed_van_dijk wrote: Depending what wheels you are running, you should get away with not changing the rack. doubtful, the box is 55mm longer than a 5 speed unit, most of this is in the arch, unless you run 4" wide wheels ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rallye1999
Does it have to be the gti6 bay loom? |
Ed_van_dijk
welshpug! wrote: ed_van_dijk wrote: Depending what wheels you are running, you should get away with not changing the rack. doubtful, the box is 55mm longer than a 5 speed unit, most of this is in the arch, unless you run 4" wide wheels ![]() It was fine on my XSi with running a Gti 6 gear box and standard rack & cyclones with 195/50/15 tyres, so a back to you! ________________________________________ Astor 6 |
you mean it fubbed like fook.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Ed_van_dijk
No, didnt touch the box at all! ________________________________________ Astor 6 |
hmmm, someone must have set the rack off to one side on the rod ends, would have handled interestingly :________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
c_j_m
rallye1999 wrote: Does it have to be the gti6 bay loom? I believe so, not checked part numbers for the 1.8 and 2.0 xsi ones though so they may work. |
Ed_van_dijk
LOL, no one set the rack up one side on the rods. Literately took the 5 speed out and put the 6 speed in and it was fine, no touching, no rubbing on full lock what so ever. ________________________________________ Astor 6 |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Yep has to be a 6 loom. The 1.8 and 2.0xsi only have 1 plug for the coil pack instead of 4 and is missing the plugs for the oil temp sensor and cam sensor. |
JWP EFi
ed_van_dijk wrote: welshpug! wrote: ed_van_dijk wrote: Depending what wheels you are running, you should get away with not changing the rack. doubtful, the box is 55mm longer than a 5 speed unit, most of this is in the arch, unless you run 4" wide wheels ![]() It was fine on my XSi with running a Gti 6 gear box and standard rack & cyclones with 195/50/15 tyres, so a back to you! ...my 6 has a 5 speed steering rack and although the tyre is very very close to gearbox on hard lock, there is no contact, currently running 50 profile tyres |
rallye1999
Niall wrote: Yep has to be a 6 loom. The 1.8 and 2.0xsi only have 1 plug for the coil pack instead of 4 and is missing the plugs for the oil temp sensor and cam sensor. That's the engine loom, |
Matt_rallye
c_j_m wrote: Matt I've got Sams old car. As for the conversion, you'll need the same phase engine bay loom, and the fuel system from a 6 (well on the 1.4 we did a xu doner may be different) along with the clocks and that should get it running with a unlocked ecu. Killed it yet? Haha |
