Author Subject: N/s driveshaft boot
footah212
Whilst trying to find the source of a mysterious clunking noise I get from the n/s front wheel , I've somehow managed to burst the inner ds boot. Anyone know how much these are from pug?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 26th Aug 2012 at 22:03
Lots, get one from a motorfactor. Avoid stretchy universal fit crap.
Posted 26th Aug 2012 at 22:18
footah212
Ok will do cheers , these come in kits with clips , grease etc yeh?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 26th Aug 2012 at 22:22
They do, also avoid the ones you fit and then have to glue together. Yes
Posted 27th Aug 2012 at 17:09
footah212
Got a QH one today from my local factor for the princely sum of 6 quid.
Just been reading another couple of threads on this looks a little more complex than I first thought. Any tips on how to stop the collets and roller bearing things from falling off the tripod when I'm twating it with a big hammer?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 27th Aug 2012 at 22:24
mechanical_repairs
Unless you are really heavy handed you will be fine, don't forget you will need new clips to refit the outer gator.
Carl
Posted 28th Aug 2012 at 09:35
i actually 'repaired' a CV boot split with tiger seal and brake cleaner and it's still fine! LOL
Posted 28th Aug 2012 at 09:49
footah212
Carl
when you say the outer gaitor do you mean the wheel side cv joint one? Do I need to take that one off?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 28th Aug 2012 at 11:29
Carl
Yes
You willl need to remove the outer CV and boot so you can slide the damaged boot off the shaft and the new one on and then slide the outer boot back on and refit the CV. Wink
Posted 28th Aug 2012 at 11:55
footah212
Carl
Yes
Getting confused. its the inner n/s boot i'm replacing, the gear box end. I thought the tripod thing had to come off in order to slide the new boot on. Didn't think i had to touch the out cv at all?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 28th Aug 2012 at 12:02
I'm under the impression from memory that the inner CV doesn't come apart in order for you to do it that way...
It's so long since I've touched one though that I could be wrong of course. Anyone confirm either way? Unsure
Posted 28th Aug 2012 at 12:12
STAN IS WRONG.
Razz
The tripod does need to come off to fit the new boot on the inner CV, wrap some tape around the tripod if you want to stop the bits from falling off.
Posted 28th Aug 2012 at 12:20
footah212
STAN IS WRONG.
Razz
Cheers Welshpug
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 28th Aug 2012 at 12:28
LOL
Well, there's your answer then, no need to touch the outer boot. Big grin
Posted 28th Aug 2012 at 13:23
footah212
Got driveshaft off eventually.
Right this bit has to come off the shaft like this?
but its got little lugs on the splines like this
I take these will straighten out when it twat lower side with the BFH?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 12th Sep 2012 at 19:29
Yes, it needs to come off that way, and then fit back on the same way. Yes
Normally they have a clip which you have to remove before you can get the tripod off, however the lugs you speak of are probably the same thing. Wink
Posted 13th Sep 2012 at 11:44
no clip there, so just drift away.
Posted 13th Sep 2012 at 11:50
footah212
Nice one lads.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 13th Sep 2012 at 12:56
mark it with Tippex so it goes back on the same splines.
Posted 13th Sep 2012 at 13:17
footah212
Will do cheers
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 13th Sep 2012 at 13:27
footah212 wrote:
Nice one lads.
You're welcome. Thumbs up
As Meirion says, make sure you mark which splines it fits on. Smile
Posted 13th Sep 2012 at 16:21
footah212
Ok have now removed the tripod, placed the new boot on and rebuilt the shaft. Replced the oil seal, slid the shaft into bothe the diff and the hub.
Trouble is I CANT get the ball joint back in. Ive tried both way s of getting it in( normal splitting at bottom of hub and undoing the 3 bolts that hold it inot the wishbone.
It seems as if the ds is too long. Or it is not going into the diff far enough. The ds measures approx 650mm long now its built back up.
There seems to be a vertical bar just inside the diff about 75mm in should it be there???. Can't get photobucket working just now or i'd show a pic.
Either that or is it possible i've disloged the outer cv slightly hence making the shaft longer.
Supposed to be at a track day tomorrow . HELP
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 15th Sep 2012 at 14:40
footah212
DSCF2319 by footah212, on Flickr
Is that bar in there normal???
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 15th Sep 2012 at 15:06
footah212
Sorted it. I must of dislodged the cv joint slightly. Smacked it with hammer and the ds shortened by about 10mm.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 15th Sep 2012 at 15:37
sounds like the outer joint had slipped past the clip.
Posted 15th Sep 2012 at 16:41
