Author Subject: Knocking from front end O/S
GTI-6
Yo
Im getting some knocking noises from my front strut. I've stuck a video on mediafire as I cant find anywhere else to upload it ( only photos on here yeah?) if anyone can point me in the right direction as to what is actually causing it.
http://www.mediafire.com/?6gxi630t166gg6u
Think I'll fit a strut brace when I get round to it too Smile
Thanks guys!
Love thy 6
Posted 25th Aug 2012 at 13:56
I can't view the video at the moment due to not being at a PC, however, things to look for would be to jack the car up and check the top strut mount for play/loose bolts. Also, check the condition of the droplink fixings and the lower ball joint for excessive play. Yes
Whilst you're under there poking around have a look at the coil spring itself and make sure it hasn't snapped or starting to fail anywhere. Smile
Posted 25th Aug 2012 at 14:19
scotzman
Top mount bearings?
Posted 25th Aug 2012 at 14:29
swiftyboi006
Top engine mount maybe?
Black p3 Love
Posted 25th Aug 2012 at 15:37
This is another good possibility, especially if the noise appears on acceleration/deceleration. Yes
Posted 25th Aug 2012 at 16:09
swiftyboi006
Easy to tell if engine mount, roll along in 1st and blip the throttle. Wen mine went it nocked everytime i done that
Black p3 Love
Posted 25th Aug 2012 at 20:07
Matt_rallye
I'd go top mount bearings too
Posted 25th Aug 2012 at 22:25
GTI-6
yeah, its not the engine mounts, quite sure of that. Happens most noticeably when just rolling over a tight left hand negative camber on the way home from work. Just as geometry of suspension goes back to normal then to the left it pops like in the vid.
I'll grab some new bearings and brace and see how i go.
Recently done the ball joints and lower control arm bushes, the drop links were fine and the coil is definitely fine. So I guess its leaves little but the top bearing.
Thanks againSmile Gotta get the 6 back on the twisties and upset some aussies in V8s Big grin
Has been getting progressively worse.
Love thy 6
Posted 26th Aug 2012 at 01:21
Based on that then, I would almost put money on it being the top mount bearings. Yes
Posted 26th Aug 2012 at 09:34
GTI-6
Stan,
Thanks for the advice mate. Spot on. Superman
replaced the drop links as a matter of course. one plastic and one metal Confused
Handles so so much better now. Got some new tyres coming and a new sterring column from T400 Pug to finish it off.
Love thy 6
Posted 9th Sep 2012 at 14:37
metal was early type, superseded by later stronger plastic type.
Posted 9th Sep 2012 at 17:11
JWP EFi
Turbo Legend!
i'm getting a ticking noise from top engine mount when decelerating, all 3 of my mounts are fooked tho
Posted 9th Sep 2012 at 22:14
This is most likely a cracked top mount cradle unfortunately. Sad
Posted 10th Sep 2012 at 13:40
