Author Subject: upper engine mount
monty-69
Anyone know if the upper engine mount near the timimg belt is meant to have a washer under it?
Posted 24th Aug 2012 at 10:39
Yes it is, a big fat 50mm one.
Posted 24th Aug 2012 at 10:40
monty-69
Thanks I'll eat some weetabix and tighten the bugger up
Posted 24th Aug 2012 at 10:45
Matt_rallye
When I replaced mine I had no washer... Also once tight I had slight movement from side to side. That normal?
Posted 24th Aug 2012 at 12:19
nope
Posted 24th Aug 2012 at 13:28
jonnie205
no washer
Posted 24th Aug 2012 at 13:37
Matt_rallye
Hmmm what would cause this movement? The lack of washer?
Posted 24th Aug 2012 at 15:21
probably smashed captive nut under the cradle, assuming the mount is alright. they are tough rubber though. i have seen a few with a big washer under them, my old xsi had one but i chucked it after getting the mount welded up properly and didn't have another problem
Posted 24th Aug 2012 at 16:08
Mine was tight,but still had movement in it.
Removed mount and found the base like this:
So could be as above pic,or your your captive nut is loose in the chassisSmile
Posted 25th Aug 2012 at 10:12
jonnie205
the buffers wear, this causes more stress on the mounting point which is only m12 into low quality steel. Eventually the metal fatigues and the mount or captive nut will break
Posted 25th Aug 2012 at 10:44
The washer has been put there for a reason though. Yes
It could be to lift the mount up slightly so it aligns the engine position perfectly, however Peugeot would not have fitted it if there wasn't a need for it to be there...
Posted 25th Aug 2012 at 12:22
24seven
There is a chance it could just be a minor correction from the factory that some cars needed and others didn't. Say a batch of the chassis panels came out slightly out of shape, or the producers of the OEM mounts had a bat batch that were 5mm too short. Slap a penny washer in there, and Robert is shaggin yer father's sister.
Posted 28th Aug 2012 at 01:09
It's possible, but as far as I know the washer is listed on Servicebox for all phases. Yes
Posted 28th Aug 2012 at 07:29
aaron6
probably to spread the load over a bigger area or to ensure the mounts sits flat and won't rattle loose. Wink
Posted 5th Sep 2012 at 13:15
Good call Aaron, that makes sense if it was done for that reason. Yes
Posted 5th Sep 2012 at 14:46
