Author Subject: brembos and mk1 focus discs
JWP EFi
Turbo Legend!
earlier today i was speaking to a guy who said he recently fitted 406 brembos to his 205, apparantly he's
fitted mark 1 focus ST discs along with 10mm spacers between the hub a caliper and using 10mm
hubcentric wheel adaptors. He said he's not had any major squealing and theres just about enough space between
the inner side of the disc and ball joint
does anyone know if this could be true?
Posted 20th Aug 2012 at 21:11
jonnie205
st170 disks are 300mm so i would imagine too large diameter but worth a try but why not stick with xantia ones?
Posted 20th Aug 2012 at 23:17
I dunno, you were the guy talking to him!
Posted 20th Aug 2012 at 23:21
JWP EFi
Turbo Legend!
jonnie205 wrote:
st170 disks are 300mm so i would image too large diameter but worth a try but wy not stick with xantia ones?
i want to keep cyclones so xantia discs would mean 20mm spacers, if ST discs are doable then i could reduce
diameter, machining not a problem Wink
btw this is just merely an idea, based on what i was told, may still be left with s**t loads of squeal!
Posted 20th Aug 2012 at 23:27
