Author Subject: Dropping subframe
mik
I need the rear of the subframe dropped due the welder needing to get under it to fix the cross-members behind the front arches.
The Haynes manual says the steering rack, arms and the gear linkage (IIRC) need to be disconnected and most of the bolts need to be undone.
If so, would it be simpler and better to just remove it entirely and get it replaced at the same time (after fixing cross-members) by the people doing the welding with my nice new/cleaned up subframe + mounts, wishbones, VTS rack etc?
The subframe and mounts on the car are nasty rusty stuff I'm getting rid of.
I'm asking as I want to plan the job to avoid duplication, extra labour charges etc.
Thanks.
Cherry Rallye SOLD
Posted 19th Aug 2012 at 21:41
jonnie205
best remove the whole lot, very easy job, then welder can do a propper job
Posted 19th Aug 2012 at 22:41
I agree, remove the lot, get all the welding work and then the painting/protecting the new steel, then rebuild using all your nice new bits you have.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Aug 2012 at 00:34
Definitely. Have the whole thing off, clean up the brackets (one of mine snapped during removal), get the subframe shot blasted and powder coated, Xsara rack on, new ram gaitors, whole lot.
It's such a b**ch of a job whether you half do it or fully do it, might as well do it right Yes
Posted 20th Aug 2012 at 08:09
Another vote for removing the whole subframe. Yes
It's not a particularly hard job, and if you can get it blasted and powdercoated as Owain suggests then it will look nice and be better protected from the elements too. Smile
Posted 20th Aug 2012 at 16:35
mik
Thanks guys, sounds like a plan.
Here is my nice clean cavity-waxed, etch-primed and painted subframe all ready to go in...
Cherry Rallye SOLD
Posted 20th Aug 2012 at 17:52
Very nice. Cool
Well worth doing in my opinion. Yes
Posted 20th Aug 2012 at 23:13
