displaying posts 1 to 25 of 30
Author Subject: Knocking/Rattle from the rear?
JayKay
This is driving me insane! There's a knock and rattle coming from the back end whilst going over even the smallest of bumps, i've had it on and off the four poster more times than i dont know what and i cant find it! I've tightened every nut, bolt and screw i can see and it has aluminium subframe mounts(don't know if this is standard). I'm at a dead end as i cant understand how anything can be rattling, any suggestions?
'Keep The 6 Between The Sticks'
Blaze Of Glory, 6 FTW
Posted 18th Aug 2012 at 21:47
fit rubber mounts, job done.
Posted 18th Aug 2012 at 23:08
Solid mounts wont make it rattle/knock.
Shocks and beam bearings ok?
Exhaust in good condition?
Posted 19th Aug 2012 at 09:27
matt evans
My moneys on the bushes in the lower shock mount, they can click/knock when under load if worn.
honestly3k wrote:
owain wrote:
Posted 19th Aug 2012 at 09:34
swiftyboi006
Rattle sounds more like exhaust, heatshield, spare wheel cage. Mounts tend to nock but not rattle
Black p3 Love
Posted 19th Aug 2012 at 09:45
jonnie205
yes solid mounts will make it rattle usually, check rear caliper bolts too
Posted 19th Aug 2012 at 10:47
greenbelt
Check your rear brake disc protectors. If they are corroded they can make it sound as if your car is about to disintegrate Wink
Standard Black 6
Black HBSC6 Smoke
Posted 19th Aug 2012 at 12:36
solid mounts might make rattles and bangs louder,but they cannot rattle or bang themselves as they are bolted to the car/beam tightlyDunno
Posted 19th Aug 2012 at 19:23
30ASTOR6
+1
TEAM ASTOR GTi 6
SNAP-ON SUBARU
SOON NOT TO BE TEAM DIABLO MEREDIAN (for sale)
Posted 19th Aug 2012 at 19:35
jonnie205
well they do, needle bearings to arm shafts are metal on metal, the play between the bearings and shafts can vibrate and rattle, same on the 206 beams, as soon as you go solid they rattle, some worse than others. Also any play in arb bushes, shocks, calipers all transmit througn the solid mounts into the shell
Posted 19th Aug 2012 at 19:49
well mine don'tThumbs up
perhaps on a old f**ked beam you would hear it more,but thats not the mounts making the noise is it?Roll eyes
Posted 19th Aug 2012 at 20:56
jonnie205
the mounts dont make the noise but they transfer any noises into shell LOL
Posted 19th Aug 2012 at 21:21
JayKay
Cheers guys, I've looked at almost all of what everyone's saying. I have no spare wheel carrier or bolt/hook so that's ruled out, full s/s exhaust and it doesn't touch anywhere(I spent hours making sure of this as it was knocking under deceleration when I got the car), There's a little rattle from the rear pads but it isn't that I can hear.... May do the shock bushes for the fun of it Smile
Posted 20th Aug 2012 at 07:30
Might be worth checking in the holes through the boot floor/box section where beam mounts are secured to car,make sure the washers are fittedWink
Could be loose rattling around in the box sectionDunno
Posted 20th Aug 2012 at 10:44
Solid rear mounts do not create a rattle from the rear of the car. They do however make any rattle that's present sound louder as there is no longer any rubber damping to absorb the noise. Yes
My guess is either as suggested shock bushes worn or beam bearings themselves worn. Wink
Posted 20th Aug 2012 at 16:15
If it's under deceleration it could be engine/chassis mount related.
Posted 20th Aug 2012 at 16:21
JayKay
Nah it's not under acceleration or deceleration, in any case I have just fitted group N engine and gearbox mounts, and I've tightened every nut and bolt I can reach, what does the "passive" rear steering? Is the beam bearings a problem?
Posted 20th Aug 2012 at 20:22
greenbelt
Seriously mate I would check the disc protectors. Takes less than a minute to see if they are the cause Yes
Standard Black 6
Black HBSC6 Smoke
Posted 20th Aug 2012 at 20:56
You haven't got passive rear steering,due to having solid mountsThumbs up
the orig mounts give the passive rear steer.
Beam bearings are a problem now as the cars are old,is there any camber on either of the rear wheels?
Posted 20th Aug 2012 at 22:09
JayKay
Hmm, That's strange as I thought I could feel lateral movement at the rear under heavy cornering....
There doesn't seem to be any camber on the rear, the beam bearings must be at fault, although I will check the disc protectors tomorrow, can the beam bearings being worn become dangerous... I.e. Is a unit going to fly off eventually? Typically when half way round a tight left-hander on the limit on a narrow country road in the small hours? Big grin
Anyone have an opinion on which mounts are best, original or solid? I'd quite like a bit of rear steer....
Posted 20th Aug 2012 at 23:39
It's all down to personal preference really when it comes to the rear mounts.
Some prefer standard ones with the passive rear steer whilst others prefer the solid. I personally would never go back to standard ones, for me the solids make the car so predictable and handle much better. Each to their own really.
As for worn beam bearings being dangerous, the fact that you haven't got any noticeable camber on the rear wheels suggests to me they're not critical as yet to be changed, but even so they don't really cause massive failures like bits flying off. Smile
Posted 21st Aug 2012 at 06:27
JayKay
Cheers Stan, I'm going to york on Monday and I suspect my clutch won't last the day at the strip so it will be straight back and on the four poster for a week or so, I'm thinking organic clutch, lightened flywheel, air con removed, one of those fandangly alloy lower pulleys and a general good going over! So I'll check all te back end out then and figure out what I want to do with the rear mounts!
Posted 21st Aug 2012 at 10:16
Agree with Stan,would never go back to standard beam mounts after solidsThumbs up
Posted 21st Aug 2012 at 10:38
from what I understand from peoples comments and my understanding of the effect they have, Its seems to me that having them is one of those things that you need to have modifications else where in the suspension to get the best out of them?
I.e Stiffing the back with a thicker arb/stiffer shocks?
i may be wrong though
Posted 21st Aug 2012 at 10:53
JayKay
I'm not sure, I'm used to big RWD cars so I'm not adverse to a "loosening" of the rear, in fact; I quite enjoy it! I know a lot of people don't like rear unpradictability though, I suppose I'd just have to try 'em out and see what happens! I'm not doing them until I find out what all this noise is though, disc protectors are fine but there is a little camber at the rear; about two or three degrees I would estimate....
I take it that's not supposed to be? How much for beam bearings, which ones and what are they like to fit anyone?
Cheers for all the help and advice fellas Thumbs up
Posted 21st Aug 2012 at 18:02
