| Author | Subject: MI16 compression |
peugeot96
Regular Location: verdal Registered: 14 Sep 2011 Posts: 218 Status: Offline |
What is the healty crank pressure on a MI16 2.0 engine? |
180+________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
peugeot96
welshpug! wrote: 180+ My is around 250, but that is with 0.5mm block decking (xu10j4). Is that to high? |
erm ![]() have you confirmed camshaft timing is correct? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
peugeot96
welshpug! wrote: erm ![]() have you confirmed camshaft timing is correct? yes the timing pins are spot on. Also the comp test was done with regrounded cams and a 4pulley inlet and 2pulley exhaust. But today i fitted a 3pulley on the inlet. I guess that will lower the comp a little bit. Have you tested the comp on a mi16 engine with with uprated cams and higher comp? |
