Bought my first GTi-6 last weekend (will get some pics up etc soon) and totally loving it! However, do have a couple of things I'd like to run past you guys...
1) When I start the car from cold each morning, it can be a little hesitant and jumpy for a couple of mins. After this it is fine, no problems at all and no lights show on dash, just seems to be first couple of mins each morning. Any suggestions?
2) Also, on a couple of occasions, have started the car in the morning (when cold) and when I've pulled up at the first junction, it has dropped in revs and cut out. Started fine after. It has only done it to me twice from memory, and only when it was cold. But once it did cut out, it started again fine and didn't do it for the rest of the journey.
The revs idle nicely most of the time, but every now and then if I go to park up, I put my foot on the clutch and I'm sure the revs sometimes pick up momentarily and then die back down again. It could just be me, but I'm certain it pops up and settles again.
As above, the hesitation and cutting out has only happened when the car was first started from cold, and within a couple of mins it is running absolutely sweet and doesn't cause any problems at all, apart from the idle sometimes dipping and coming back up again. But once the car is sat still and the idle has settled, it is fine.
Could all these problems be linked?
Appreciate any help guys
ash j
