Author Subject: 2nd gear issue
JWP EFi
Turbo Legend!
i've just got myself another GTi6, the clutch is heavily worn but doesn't slip however it judders like hell
anyway when i drive it normal all gears are fine, if i try hurried changes into second it crunches...
i had a similar problem with a previous 6 but in third, i changed the clutch and all was well. i dont really fancy
changing the clutch then only to find out the problem remains
any thoughts?
Posted 9th Aug 2012 at 20:46
scotzman
Have you tried changing the gearbox oil?
Made a huge difference to mine.
Posted 9th Aug 2012 at 20:50
JWP EFi
Turbo Legend!
nah, only got her last night, hoping its just the clutch, got a valeo kit to go in
Posted 9th Aug 2012 at 20:52
miles
Oil first, But if fitted with a Q/S they do bulk, Mines horried and when I get 5 min's I'm taking it off as the changes take longer with the silly thing fitted
www.pugracing.com
Posted 9th Aug 2012 at 23:47
7057sam
I have recently changed cultch,gearbox oil and jose joint linkages and gear changes still don t feel that much better.Think the box is on the way out ?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 10th Aug 2012 at 00:03
iplay
check the rubber ball has not worn in the gear lever swivel arm (not sure of the correct name) ?
Posted 10th Aug 2012 at 00:30
iplay
any thoughts?
it is worth changing the oil first.
sounds like the return springs are failing on the clutch which is quite common.
Posted 10th Aug 2012 at 00:33
mattgti6phase2
The judder is more than likely the pressure plate being fooked! As for the gear crunch I'd put money on it being the wrong box oil. I had the same issue when i bought my 6 and as soon as i changed it for the genuine Peugeot oil the crunch completely disappeard and still to this day its perfect.
In comparison to other 75/80w gear oils the pug stuff is like water which the BE boxes obviously love. Give it a go because either which way you'll need a new clutch.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 10th Aug 2012 at 01:29
The clutch being heavily worn will obviously require replacing. This will also solve the issue of judder as the friction plate being warped is what is causing this. Yes
As for the crunch into 2nd when changing quick but it's fine when changing slow gives me the impression that the synchro is on its way out...change the box oil first as has been said for the proper Pug stuff, you may be lucky and find this cures it, but I suspect you will end up needing a synchro to cure it fully. Yes
Posted 10th Aug 2012 at 06:44
JWP EFi
Turbo Legend!
ok guys cheers for that, ive just about bought a box from someone on here, i will however
try oil change when i get time, if it does cure it at least i'll have spare box if i ever need it
Posted 10th Aug 2012 at 22:13
Oil change is the easiest (and cheapest) thing to do so give that a go first. Thumbs up
Posted 11th Aug 2012 at 08:07
stan_306gti6 wrote:
Oil change is the easiest (and cheapest) thing thing to do so give that a go first. Thumbs up
Bit late considering he appears to have bought a box. Whistle
Posted 11th Aug 2012 at 08:18
Not really, as he said, he now has a spare box if an oil change does fix it. Yes
Posted 11th Aug 2012 at 13:59
JWP EFi
Turbo Legend!
small update, i changed the box oil with the proper Peugeot stuff (£27 lol) and there is no
difference, ok all other gears a wee bit smoother but 2nd still crunches
not too fussed though as box has to come out for new clutch which eddiebeano will be
collecting from eddygti6 tomorrow - Cheers lads!
Posted 11th Aug 2012 at 15:08
Did the oil change fix it Hmm think not. We need myth busters on here to prove that the placebo effect of changing the gearbox oil is not even that. It's generally a waste of money on gearbox oil.
Posted 11th Aug 2012 at 15:31
JWP EFi
Turbo Legend!
now now guys!
was worth a try i thought
Posted 11th Aug 2012 at 15:34
Laugh It's a try we've all had...
How/why have you owned 18 306's?
Posted 11th Aug 2012 at 15:37
Laugh my ass off @ Jon!
If the gearbox oil that was fitted was incorrect then it could well have fixed it. However, if the oil was already correct then as I said above, I suspect the synchro is on its way out...Smile
Posted 11th Aug 2012 at 17:16
Just be aware people have fitted new clutches to these,and the judder returns pretty quicklyThumbs down
I would get a spare flywheel surface ground ready for when you do clutchWink
or do what I did,treat yourself to a billet lightened flywheelCool
looking at my old flywheel it looks to have got high spots on it.
Posted 11th Aug 2012 at 17:49
JWP EFi
Turbo Legend!
because i like a hard life lol...erm other than the s**t build quality
I just them, had every model bar the cab and rallye
Posted 11th Aug 2012 at 17:58
