Author Subject: MI16 cams
peugeot96
Is it waste of time and money fitting uprated cam on the exhaust side on the mi16 engine?
Posted 7th Aug 2012 at 10:15
without doing the intake yes.
Posted 7th Aug 2012 at 11:16
peugeot96
I got uprated on the inlet side, but I see petert say the clue is not to touch the exhaust.
Posted 7th Aug 2012 at 12:03
for initial tuning that's probably quite right, if you go wilder you'll need higher compression and more valve clearance.
Posted 7th Aug 2012 at 12:14
peugeot96
Im running 11-1 comp. But what is the inlet exhaust balance (80%) petert talk about. Im running on 42mm itbs.
Both inlet and exhaust cams are the same 264deg and 9,6 lift. Would it be better to fit a std exhaust cam?
Posted 7th Aug 2012 at 13:19
