Author Subject: starting an engine that's been stood a long time.
binkagti
As per title. engine has not turned for a couple of years what's best for it. full service fluid flush cambelt water pump tensioner.
TEAM Supercharged Rallye
Posted 6th Aug 2012 at 14:13
up to you, you can just start it with fresh oil or just turn it over a few times by hand / start it without coilpacks plugged in for a few turns, then start as normal
i had my s16 engine out of the car for about 6 months and did the above before running it first time
Posted 6th Aug 2012 at 14:20
whip the plugs out, spin it on the starter till the oil light goes out.
Posted 6th Aug 2012 at 14:37
^^This
Then once you've got the engine up to temp, switch it off, drain all fluids and change filters. Refill fluids and do a belt change. Yes
Posted 6th Aug 2012 at 16:05
Squirt a little oil down each bore after you remove the pulgs and before you spin it over, even duck oil or WD40 helps, just don't flood it with the stuff, a one second burst from an aerosol is good enough.
Posted 6th Aug 2012 at 16:12
