Author Subject: 283 offset
JWP EFi
Turbo Legend!
Quick question, does anyone know the offset of gti6 283 disc?
Posted 5th Aug 2012 at 21:55
Rich E Forum Admin
Not of the top of my head, but Brembo carry technical drawings of all their discs on their aftermarket catalogue so it's probably on there.
http://www.bremboaftermarket.com/En/Car_Disc_Catalogue/Catalogue_Search.aspx
Posted 5th Aug 2012 at 22:05
JWP EFi
Turbo Legend!
just had a quick look but cant see offsets, wheres welshpug when you need him lol
Posted 5th Aug 2012 at 22:10
Rich E Forum Admin
Lol, no, you'll need to calculate it yourself based on what you mean by offset. All the measurements you need are there.
Posted 5th Aug 2012 at 22:22
JWP EFi
Turbo Legend!
....basically what i'm looking into is running the 406 brembos AND keeping the cyclones, i really don't
fancy having my wheels hanging off 20mm spacers, so i'm thinking of spacing the calipers away from
the hubs hence why i need to know offset. i have been looking at bells etc on hispec site, prices seem
reasonable so aiming to do all this and use say 10mm hubcentric adaptors, machining isnt too
much off a problem as my mate does this for a living
yes it's probably pointless but i want brembos and clones!
Posted 5th Aug 2012 at 22:42
the discs you need to use as a straight bolt on are the brembo 09.7877.10.
overall height is 34.2mm, thickness of 28.1, bell thickness of 7mm, so effective offset inwards of 0.9mm from the face of the drive flange.
Posted 5th Aug 2012 at 22:55
JWP EFi
Turbo Legend!
bloody hell welshpug, can you translate that into english please lol!
don't suppose you know what thickness of spacer i would need??
Posted 5th Aug 2012 at 22:58
Rich E Forum Admin
Trouble is Mei, he wants to move the calipers (and therefore discs) inwards to minimise the distance the wheels (cyclones in this case) need to be spaced outwards.
Clearance between the balljoints and the inner face of the discs will be the critical factor to consider with that plan. That's what will determine how far the caliper and disc assembly can be moved inwards, and it's a pretty close affair to begin with.
Posted 5th Aug 2012 at 23:02
JWP EFi
Turbo Legend!
xantia discs???
depends how much space there is under the wheels, you need to stick the calipers on without a disc and see how far away from the lugs they need to be, that'll five you the offset for the bell and the spacer needed for the caliper, but don't forget about clearance to the balljoint and steering arm on the hub.
Posted 5th Aug 2012 at 23:04
JWP EFi
Turbo Legend!
Clearance between the balljoints and the inner face of the discs will be the critical factor to consider with that plan. That's what will determine how far the assembly can be moved inwards.
good point, looking at my existing 283 setup, the discs are already fairly close to b.joints, so now thinking this
latest brainwave is donald ducked! btw, can you still get copies of clones? i know there are few people with 17''
'lions' i think they were called, did they do 16's?
Posted 5th Aug 2012 at 23:08
peetypug
Afaik lions are over £1000 a set! They didn't do 16s either Sad
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 6th Aug 2012 at 08:08
Personally, I see no merits to owning them tbh,
They buckle like cheese and are heavy and hilariously expensive.
I not sure they totally capture the look of the cyclone either
Posted 6th Aug 2012 at 09:09
chrisd306
should of bought wilwoods that you can run under cyclones of you wanted to keep them, or just bin them an get some 15" speedlines or team dynamics or comp mos or something like that, as more hassel than its worth moving callipers an finding discs to suit!!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 6th Aug 2012 at 10:29
just buy decent pads, job done Razz
Posted 6th Aug 2012 at 10:57
