Author Subject: Offside Headlamp Earth Wire keeps Burning Out Help
Teshboi1988
as stated above. any ideas guys? where does the earth wire lead to? could it be wires touching or bad earth could just need a clean??
the spade connector actually glows sometimes... iv put copper grease over it to slow it down bt need to resolve...
thanks tesh
phase 3 Hatchback V reg 5Door GTi6
Posted 3rd Aug 2012 at 20:33
tvrfan007
Have you checked the condition of the other earths?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 4th Aug 2012 at 05:33
+1
Sounds like the other Earths are not doing their job correctly and this Earthing point is doing too much as a result.
Posted 5th Aug 2012 at 07:03
Teshboi1988
no i havent... dont know where to start...
what you recommend i do 1st?
Posted 5th Aug 2012 at 11:00
Remove and clean all earthing points in the engine bay, then refit and tighten. Smile
You will find an Earth on the inner nearside wing just in front of the battery box, and one on top of the gearbox. Yes
Look at these two first...
Posted 5th Aug 2012 at 22:34
Teshboi1988
just them 2 yea?
brillant thanks stan!
Posted 6th Aug 2012 at 20:34
Have you checked the wiring in the headlight ?
Also check the plugs and connections on the outside of the light Thumbs up
Posted 6th Aug 2012 at 20:43
BlackSix
yeah, id be checking the connections on the headlights. if the connection is loose it can cause this to happen
Posted 6th Aug 2012 at 21:32
Teshboi1988
thanks for advice guys
Posted 6th Aug 2012 at 21:37
