Author Subject: refusing to communicate with diagnostics
BlackSix
went to get my arse of a car plugged in again today with a snap on solus, wouldnt communicate.
tried pug planet with the right build code, wouldnt communicate.
the only one up til now that would is a bosch diagnostic which is showing lambda malfunction type 2.
got someone to have a look at it and he feels sure its an electrical fault.
if i dont get to the bottom of this issue soon, its getting broken. had enough now
Posted 3rd Aug 2012 at 13:27
Its deffo the ecu then surely
Sounds absolutey fecked
Or maybe a weird loom issue.
Posted 3rd Aug 2012 at 13:31
BlackSix
ive left it with a garage to try and get to the bottom of it but its been made clear that i wont be paying for anything unless its sorted or the problem is at very least diagnosed accurately.
ive done continuity checks from the ecu pins to most of the sensors and they come back fine so the only real obvious solution is ecu itself.
thing is, everything else ive replaced seemed to be the logical solution at the time lol
Posted 3rd Aug 2012 at 13:44
Yeah but no one expects a fault to be something like that do they? I'd put money on it now tbh.
Sounds like its slowing on its way out
Posted 3rd Aug 2012 at 13:46
BlackSix
theyre now saying they want to try another full set of coil packs......apparently if its not that, they can just send them back to the supplier so wont cost me anything unless that is the fault so almost worth letting them try it just for grins.
i got a few pm's in reply to my wanted thread so early next week il most likely end up buying one.
Posted 3rd Aug 2012 at 13:53
I'd be surprised if its that tbh :S they run on two in my experience
Posted 3rd Aug 2012 at 13:58
BlackSix
they dont seem to be listening to what ive already checked/replaced tbh. just had to tell them again that i wont be paying xxx hours labour if they end up not being able to diagnose with certainty, and the guy at the counter said he doesnt expect me to so its all good il let them do what they like til they find it.
it does run, just idles like a sack of s**t and misfires once in a while at part throttle
Posted 3rd Aug 2012 at 14:12
let us know what was, Learning experience for us all really Smile
Posted 3rd Aug 2012 at 16:28
is it a 6? sounds like a map fault or lambda.
Posted 3rd Aug 2012 at 16:42
BlackSix
both map and lambda been replaced with new parts mate, and continuity checked wires from ecu to both sensors. also, the engine dies when i unplug the map sensor.
yeah its a 6. when i find it il defo post a solution
also, having to replace the ecu....been told its a death sentence and even unlocked ecus can lock themselves.....can anyone explain that?
Posted 3rd Aug 2012 at 16:48
I know theres a certain way to do it or you re lock it.
Posted 3rd Aug 2012 at 16:56
PM Rich_W, he's knows the ins and outs of the Marelli ECU.
Posted 3rd Aug 2012 at 17:12
BlackSix
making enquiries about getting an ecu Smile looking to get one today if possible
Posted 4th Aug 2012 at 12:33
As mentioned Rich_W will be able to supply you with a guaranteed unlocked ECU which won't relock itself, may be worth a go now as everything seems to point in that direction.
Posted 5th Aug 2012 at 07:00
BlackSix
as the other thread, tried one today, same problem still there Sad
Posted 5th Aug 2012 at 22:47
Loom?
I mean tbh If the sensors are all fine and the ecu is fine it can surely only be the Inbetween...
Posted 6th Aug 2012 at 16:03
I would recommend continiuing all the discussion in this thread instead
http://www.306gti6.com/forum/showthread.php?id=149789&page=2
As I have a feeling its all one big issue.
Going on what is in the above thread your fuel pump sounds a bit suspect tbh.
But as for why it doesnt communicate its all a bit messy...
Posted 6th Aug 2012 at 16:16
