Author Subject: ecu tapping after engine change
pugpower1986
hey guys help needed
have changed engines in my rallye got a newer engine out of a xsara vts, changed all the sensors ova.
filled the car with new box oil,water about to bleed the system turned the key so ignition lights come on , then a horrible tapping like tap,tap,tap,tap was comin from the ecu..
hmmmm
i fink its a bad earth just fort has anybody else had this issue as i need it sorted asap
cheers in advance guys
Smile
98 Cherry Rallye
98 cherry 106 gti
Te@m Cherry Smile
Posted 1st Aug 2012 at 23:29
darzmat
could be the fuel relay which is located next to or underneath the battery/ecu.
Posted 2nd Aug 2012 at 00:32
Ecu has no moving parts so it cant tap, but check the relay as mentioned
Posted 2nd Aug 2012 at 08:30
pugpower1986
cheers guys i sorted it... it was the earth on the box needed sand paperin then boom its all gd Smile
98 Cherry Rallye
98 cherry 106 gti
Te@m Cherry Smile
Posted 2nd Aug 2012 at 22:19
As just gonna say had this plus all the interior electrics not working properly when I changed my engine. Left the nut on the inner wing earth loose DOH!
Posted 3rd Aug 2012 at 08:04
