| Author | Subject: Side strip clips |
parrotno1
Regular Location: Wiltshire Registered: 01 Jul 2005 Posts: 154 Status: Offline |
Does any one know the part number for these? Cheers |
856540 20p each.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
parrotno1
Cheers, am I right in thinking they are different from phase 2 to 3? |
upto rpo 8210 6995X3 26p note to self don't just enter my vin when searching for parts for others.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
parrotno1
I'm confused, sorry for being a simpleton! |
There is a difference based on when car was made.If you have a phase 2 car you need 6995X3 26p If you have a phase 3 car you need 856540 20p Mileage thread says 1999 so could be either. You referred to phase 2 so thought you had a phase 2 after providing the phase 3 part. Simple question are the existing side stripes you need the clips for rounded and colour coded? If not it's phase 2 stripes. ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
parrotno1
Phase 3 then I'll b needing. ,cheers thug puggin! |
parrotno1
The hole near the wing looks different to the rest of the holes, it's a small oblong where the others are a round hole, does that still take the same clip? |
parrotno1 wrote: The hole near the wing looks different to the rest of the holes, it's a small oblong where the others are a round hole, does that still take the same clip? Pretty sure I've read on here you need to use tiger seal/PU adhesive on part of the wing trim,could be wrong though! ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
parrotno1
Sorry I meant the hole on the door nearest the Wing, noticed its oblong not round like all the rest?!! |
parrotno1 wrote: Sorry I meant the hole on the door nearest the Wing, noticed its oblong not round like all the rest?!! No clip showing on Service Box for that hole Looks like trim should have a piece on it to pop into that hole? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
parrotno1
Ok cool, cheers |
Just to confirm there should be a small 'L' shaped piece of plastic on the door trims,which goes into the oblong hole first before clipping trim to door,you put this in then slide the door trim backwards before pushing clips in So to remove the door trims correctly without snapping this off you need to start removing from the rear of door,then once the last clip is out of door slide the trim forwards to release the 'L' shaped piece of plasticYou need door open to get it off without breaking it ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
