Author Subject: 406 brembos on 302mm discs.
dum-dum
Has anyone tried the 406 coupe brembos on the 307 302mm discs, theyer 2mm thinner but the same overall height compared to xantia V6 discs so may be able to space the caliper in 1mm.
Can anyone with the brembos fitted on xantia V6 discs see if there is 7mm of clearance between the disc and the caliper.
Bianca GTi6 on Gold wheels. Let the haters hate.
Posted 23rd Jul 2012 at 17:33
dum-dum
Seriously people? more than 50 of you have viewed this and not one of you can tell me if they do or dont fit?
Posted 24th Jul 2012 at 19:16
jorg
I don't think they will fit, pretty sure the max diameter disc you can use with 406 brembos on a 306 is around the 295mm area
306 2.1 S16 Tarmac Rally Car
Posted 24th Jul 2012 at 19:40
7057sam
Pretty shure someone on here as a high spec disk conversion which allows 302mm
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 24th Jul 2012 at 22:47
7057sam
Tell a lie he running 330x28mm Hi Spec Front Discs
Rallye dead Sad
Posted 24th Jul 2012 at 23:01
I think you would need something to extend the 306 hub out to the size of 406 one. in order to maintain the same gap between the caliper and centre of the hub.
Posted 25th Jul 2012 at 10:28
There are other conversions that take 302mm
Mine will be for example Just need to find the damn calipers.
807v6 ones they are
Posted 25th Jul 2012 at 10:29
dum-dum
Ok, I thought it would work cos people always say you cant use the 305mm 406 discs cos of the offset of the disc not cos of the diameter of the disc. thanks all.
Anyone got any pics of brembos fitted on 288mm discs?
Posted 25th Jul 2012 at 18:27
I thought it was all down to the positioning of the mounts on the two hubs.. maybe im wrong.
Posted 25th Jul 2012 at 22:12
Check the 4 oot conversions thread.
Probably my fave thresd that one :p
Posted 25th Jul 2012 at 22:13
dum-dum
Got a pair of Brembos now (£80 scrap yard bargain), gonna see if they fit over 6 discs and if Ive then got 10mm of clearance. as 283mm + (10mm x 2) = 303mm
Posted 25th Jul 2012 at 22:43
http://www.306gti6.com/forum/showthread.php?id=95186
you want this thread its just interesting in general Razz
Posted 26th Jul 2012 at 09:27
JWP EFi
Turbo Legend!
you wont be able to fit 302's with brembos on standard mounts. i got my brembos today and trial fitted them with 283's
there isnt much clearance between outer edge of disc and caliper
Posted 2nd Aug 2012 at 22:13
you want 288x28.
Posted 2nd Aug 2012 at 22:26
