displaying posts 26 to 33 of 33
Pages (2): 1 [2]
Author Subject: Miles Links - PTFE Bush?
Tallguy_2
I meant match the length of the new ones to the old one to try and get it right? Is that a battery and tray out jobbie then?
"winners come and go but legends never die..."
autorite-sport.co.uk
Posted 23rd Jan 2013 at 23:59
I tried to do this not long ago,
I was freaked out I was about to break something so left it for now until i have a bit more time
Posted 24th Jan 2013 at 09:25
honestly3k
You do have to take the battery tray and ecu out to get good access to the rod area.
Doesnt look too hard once you seen it done (matt did mine), just fiddly, really fiddly so have patience!
Also worth mentioning that i did grease my uprated rods but they do rattle like f**k when on WOT going through the gears.
Doesnt really bother me to be honest as most of the time i have my music on anyway
Gear change is not much different to previous really but i think thats because my original setup was in good nick so if you have a current sloppy gearchange then they should improve things alot
Posted 24th Jan 2013 at 23:42
Can be done without removing battery/trayYes
Fiddly yeah,but pretty easyThumbs up
Just don't drop the retaining clips!!No
Your a girl fairdo's!!!LOL
Posted 25th Jan 2013 at 09:51
24seven
Just pull harder! Worst that can happen is you'll punch yourself in the face when it pops off, but if the ball joint is that tight in the first place it probably doesn't need replacing.
Posted 25th Jan 2013 at 19:25
I even tried the spanner under the joint trick and was like I AM GOING TO f**kING SNAP SOMETHING HERE lol.
Ill give it another go when i change the gearbox mount as it will likely be 10x easier
Posted 25th Jan 2013 at 23:13
Tallguy_2
So the easiest way is to do them from the top down then for sure?
Posted 27th Jan 2013 at 10:15
Tallguy_2
Had a crack, 13mm works a treat plenty of grease in there, clips on, jobs a good'un!
Posted 27th Jan 2013 at 13:21
Pages (2): 1 [2]
