| Author | Subject: Wilwoods? |
eddy_gti6
Just bought a set of wilwoods with ford fitment braxkets. Will they fit a 306? There to go on my saxo but prety much same fitment as a 306 anyway. Also anyone tell me where i can get discs and what size i can run under 15s?________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
depends what brackets you get as to what discs you need, as if you get welly brackets you run standard discs, failing that an you get 205 brackets like what i had you have to use rally design discs id try them for brackets to, but id imagine you will be 200 plus for what nyou need________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
eddy_gti6
No way i could run the 288mm xantia v6 discs thats used with the brembos? What size are the rally design discs?________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Also need different front hoses as willwood use a taper fitting!!!The rest of your lines will hopefully be with me tomorrow |
eddiebeano
Senior User Location: Edinburgh Registered: 31 Dec 2008 Posts: 715 Status: Offline |
A saxo!________________________________________ team: Stealth |
eddy_gti6
How much more for these swampy? Pm me. Yes eddie a saxo. Bought a rolling shell and cost of parts so far is over £500 and i still dont even have an engine to go in it ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
mr swampy s16
£27.50 the pair, direct fitSame paypal |
eddiebeano
Is it going to be something spectacular?________________________________________ team: Stealth |
eddy_gti6
eddiebeano wrote: Is it going to be something spectacular? It was going to be a gti6 engined saxo but too much work involved so probs just get some head work done, cams and a map. Them see where i end up after then flocked dash i have just had done is class ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddy_gti6
mr swampy s16 wrote: £27.50 the pair, direct fit Same paypal You have pm ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddy_gti6
eddiebeano
Where did you get your dash done Eddy?I have one sat in the garage waiting. I forgot to ask also. How dd the exhaust sound as it left ![]() ________________________________________ team: Stealth |
eddy_gti6
Sounded class mate. Loved that exhaust. Might get same set up done for the VTS ![]() Lad down my way does it. £80 for my saxo dash but not sure how much a 306 dash will be? Al text you his number. ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
eddiebeano
Cheers mate, may see about this next time in down Durham way, will have to pop in and see your new motor too ![]() ________________________________________ team: Stealth |
eddy_gti6
Well am away for 2 weeks now. Just about to set off to manchester so give me a shout if your down in august and come for a look. Might have an engine by then ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
dav1
Regular Location: leek/staffs Registered: 20 Jun 2011 Posts: 312 Status: Offline |
Eddy you interested in a 155bhp saxo with willwoods, omex, piper pulleys, Kent cams Oz multi spokes the whole car loads good bits on 1500 ________________________________________ 230bhp 205 gti6 |
chrisd306
no need the rally design discs if 205 brackets as its all to do with the offset just like my kads have the 205 brackets! there 285mm, R turbo 21 or 11 discs are ment to fit but i tried for long enough to try an find some, reason i punted them, an i bought the kads although they were ment to be gti6 brackets but after removing discs they were not!if welly kit standard gti6 discs ________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
eddy_gti6
Calipers have came, need to check my brackets with a mate of mine who is also running wilwoods to see if the brackets are the same or not then will go from there. ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
