Author Subject: peoples recommendations...
tom28
Hi all, i'm a regular on here but kinda lurk in the shadows and so am not well known by other members so if you don't know me already i'm tom by the way LOL
Anyways, i have a ph 3 china 6 and it has had head work done to it in the past due to signs of head gasket failure. i know for sure that it has had the head skimmed but don't know by how much Unsure I am intereseted in a change of cams but unsure of the correct way of getting this done without it all going wrong. currently i am considering the pug1off cat cams setup which they rave about on their website and it has proven good results, i would just like to hear what you guys think about this and if you have any recommendations/advice on what you would do? or what you would go for?
ideal spec: running around 190/195ish
cheerz in advance peeps
Tom P
Posted 18th Jul 2012 at 23:43
anth
Optimistic for cams only I would say.
Posted 19th Jul 2012 at 07:01
bodies and that's it without opening it up and enlarging valve cutouts, you can measure the head in place though to see how much was taken off, where was it done and what gasket was used?
Posted 19th Jul 2012 at 08:25
swiftyboi006
Cams + remap = £700-£900 depending what cams and where you go, aprox 180-188 depending on engine health
Cams + ITB's + remap = about £2200- £3200 depending where you get them, this setup can see around 195-220
To reach the higher end of that mark more lairy cams need to be fittet with advanced timing machined pistons, tese can be done for £150-£250 mark depending on where you go
Black p3 Love
Posted 20th Jul 2012 at 06:50
tom28
yippy was the previous owner and a guy named mike did all the work.... have been told only o.e items where used if that helps
Posted 20th Jul 2012 at 18:51
tom28
I quote from the cat cams website:
"Following on from the results below, Pug1off re-tested the 4903106 profile on another car just to check the results.
This time the engine already had a 'Piper' Inlet only camshaft and made 178bhp on RS Tuning's rolling road. After the initial test the cams were replaced with a pair of 4903106 Catcams and remapped to suit.
The final results are 193bhp with gains from 2000rpm over the previous setup!
The owner reports this has transformed the way the car drives
Back to back dyno testing on Northampton Motorsport’s dyno by Peugeot specialist Pug1off has shown (when used in conjunction with a suitable ECU remap) that the Cat Cams 4903106 profiles produce exceptional power gains, in this case 26 bhp.
Crucially, both power and torque are improved throughout the rev range, with a 17 lb.ft peak torque increase and 10-12 lb.ft extra at 4500 rpm, making this an ideal fast road upgrade.
During testing the peak power increased to 181 bhp at 7500 rpm, with over 175 bhp available from 6100 – 8000 rpm.
(NOTE: The stock car seemed down on power, producing 155 bhp but this could be as a result of the 145,000 mileage.)
As a result of the Cat Cams / Pug1off ECU remap package, peak torque increased to 150 lb.ft on the high mileage test car.
Available now from Cat Cams stockists, the 4903106 profiles for the XU10J4RS engine used in the
Peugeot 306 GTi-6 and Rallye are available now, priced at £486.00 including VAT."
VERY TEMPTED BY THIS with the results that are produced.....
Posted 20th Jul 2012 at 19:02
dav1
If you get pug1off to do it get a rolling road done before hand then they will tell you if they think they can reach the target they say. Ive found them very good an helpful. Matts built some great engines an has records to prove. Iam may selling my gti6 engine on jenvey 48's, omex, an piper cams 215bhp 170lbft drop it in and your awayBig grin. In for sale section
230bhp 205 gti6
Posted 20th Jul 2012 at 19:03
