Author Subject: Quickshift Issue
webster
Hi,
I think it's a compbrake quickshift - basically it started becoming loose, figured it was the grub screws so tightened those at the weekend but turned out it wasn't.
Here's how it should sit:
Here's how it does sit & the movement:
Is it f**ked? Or does something just need to be done back up / re-attached.
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 16th Jul 2012 at 07:01
is it to do with the bushes inside it? doesn't miles do one like this as well?
Posted 16th Jul 2012 at 07:09
webster
No idea, all my knowledge of it is in the post above Big grin
It's not very old...
Posted 16th Jul 2012 at 07:14
theres a collar underneath too.
Posted 16th Jul 2012 at 08:39
webster
Ah, so likely that one has become loose?
How do I get to the one underneath? undo the four bolts?
I'm not good at cars at all, is it best to get a mechanic to do it?
Posted 16th Jul 2012 at 08:48
Matt_rallye
There is a fitting guide over on 306oc.co.uk that might help you out abit.
I'll see if I can find it, if not its in the guides section
Posted 16th Jul 2012 at 09:17
webster
Thanks mate i'll trawl through now.
Posted 16th Jul 2012 at 10:28
webster
http://306oc.co.uk/forum/thread-1477.html?highlight=quickshift
Found the thread, I think i'll take it to the garage and get them to sort unless anth can do it with me.
Posted 16th Jul 2012 at 10:30
Matt_rallye
It's a good guide, not too hard to do, just need to fit mine now lol
Posted 16th Jul 2012 at 10:39
Matt_rallye
jack it up, loosen the upper grub screw + slide stick down, position lower collar +secure in place, push back up and position upwer collar.
easy, no need to pay someone to do it.
Posted 16th Jul 2012 at 10:54
webster
Ok so once the car is jacked up it's easy to get to that bit?
Posted 16th Jul 2012 at 11:11
very
Posted 16th Jul 2012 at 12:21
Blob of mig weld on each collar stops this.
Posted 16th Jul 2012 at 12:24
miles
Poor design, I do sell these but not for 6's due to the lift reverse, Basically you really need new collar's machining up to stop this happening
www.pugracing.com
Posted 16th Jul 2012 at 14:54
CAT heatsheild will need removing won't it to gain access?
Posted 16th Jul 2012 at 21:37
isnt there a hole in the middle of it for the stick to poke through? there is on my zx Unsure
even then, it'll only be 4 nuts.
Posted 16th Jul 2012 at 21:42
99% sure theres notNo
+ pretty sure you have to bend them to s**t to remove them with CAT still fittedThumbs down
Posted 16th Jul 2012 at 21:45
webster
Garage it is then, thanks all.
Posted 16th Jul 2012 at 22:49
what a c**t, ZX FTW! Laugh my ass off
Posted 16th Jul 2012 at 23:15
